Author Topic: Help on turning off specific xref layer  (Read 6285 times)
diego65
  • Learning LISP is a cool thing
« on: December 06, 2012, 03:52:47 PM »
Hello,
I need help on creating a routine that will allowed me to turn ON or Off a specific layer on a bunch of drawings.
The point is for not to open every single drawing and turn the layer off manually.
Any help will be appreciate it...
Thank you...
BlackBox
Re: Help on turning off specific xref layer
« Reply #1 on: December 06, 2012, 04:52:29 PM »
You'll want to iterate a list of valid Drawings using ObjectDBX, then within each DBXDocument Object, iterate the Layers Collection, checking for matching Layer Names, if a valid match, then toggle that Layer Object's LayerOn Property accordingly.
diego65
« Reply #2 on: December 06, 2012, 05:13:56 PM »
Hi RenderMan,
That is exactly what I am lookng for, however, I am very familiar with LISP.
I am looking for help on creating one from scratch if I can get some help...
BlackBox
« Reply #3 on: December 06, 2012, 05:35:51 PM »
Hi RenderMan,
Any routine involving ObjectDBX (appropriately) requires a bit more effort and error handling than a typical requests for help. I, or someone more knowledgeable than I, will post back as time permits.
« Reply #4 on: December 06, 2012, 06:12:51 PM »
This function will do all of the ObjectDBX work for you:
http://lee-mac.com/odbxbase.html
Load it and call it with the following program (change the layer name to suit):
(defun c:frzlay ( )
    (LM:ODBX
        (function
            (lambda ( doc / lay )
                    (not
                        (vl-catch-all-error-p
                            (setq lay
                                (vl-catch-all-apply 'vla-item
                                    (list (vla-get-layers doc) "Your-Layer-Here")
                    (vla-put-layeron lay :vlax-true)
        nil t
The above is untested.
« Reply #5 on: December 06, 2012, 08:43:23 PM »
Lee your ObjectDBX helper routine is a real time saver.  8-)
« Reply #6 on: December 07, 2012, 05:56:55 AM »
Thanks Alan!  :-)
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: December 07, 2012, 11:20:05 AM »
Lee, I have not been over to your site for some time.  I really, really, really like option to preview the code in HTML.  Very sweet.
And the code looks sweet too.  Filed that in back of my brain for when a future need arises.  ;-)
diego65
« Reply #8 on: December 07, 2012, 01:06:50 PM »
Thank you Lee Mac for helping me out on the script for “Turning specific layer ON or Off in multiples files without opening them”
It works wonderful, however, I forgot to mentioned that, this specific layer is located on an xreference file, sorry.
Would you be able to help me on this one please?
Thank you…
Joselo…
« Reply #9 on: December 07, 2012, 04:33:30 PM »
Cheers Krushert! I'm glad you like it 8-)
I hope the program is of use to you :-)
« Reply #10 on: December 07, 2012, 04:36:46 PM »
You're welcome Joselo  :-)
Although XRefs are not loaded when interfacing with a drawing using ObjectDBX, the XRef-dependent Layers should still be present in the drawing's Layers Collection, hence, you should be able to use the program for your case and specify the name of your XRef-dependent Layer.
GDF
« Reply #11 on: December 10, 2012, 09:27:07 AM »
(defun c:frzlay ( )
    (LM:ODBX
        (function
                    (not
                            (setq lay
        nil t
Lee
Is it possible to use the following in place of "your-layer-here"?
(list (vla-get-layers doc) "*AREA*,UT*|*PATT*,UT*|*DIMS*,UT*|*NOTE*,UT*|*SYMB*,UT*|*SHTT*,BL-0*|*SHTT*,*|A-CLNG-HEAD,*|A-DOOR-CODE,*|*-2,*|*-3")
« Last Edit: December 10, 2012, 09:32:59 AM by GDF »
« Reply #12 on: December 10, 2012, 09:34:02 AM »
Is it possible to us the following in place of "your-layer-here"?
The OP actually posed this question via PM, here was my response:
Quote from: Response to PM from OP
The current function is looking for an exact layer name match, and cannot accept wildcards.
To use wildcards, the code must be changed to:
(defun c:frzlay ( )
    (LM:ODBX
        (function
                (vlax-for lay (vla-get-layers doc)
                    (if (wcmatch (strcase (vla-get-name lay)) "wildcard-match-here")
        nil t
In future, please reply to the forum thread rather than sending a personal message, as the replies will then benefit the whole forum community.
diego65
« Reply #13 on: December 10, 2012, 10:05:49 AM »
Thank you Lee Mac,
This routine is a life saver, that was exactly what we were looking for.
Very well done...
Joselo...
GDF
« Reply #14 on: December 10, 2012, 10:16:14 AM »
Lee
Thanks for your response. I have a more specific question and help needed. I will ask it on your website. I will pay for your services for this help. You can then post the solution here to benefit the forum.
Gary
