Author Topic: Updating Indexes for block *MODEL_SPACE  (Read 2342 times)
jonesy
  • SuperMod
« on: March 09, 2005, 04:44:04 AM »
I have had this message appear on 2 or 3 of my drawings. Does anyone know what it is and where it has come from.
Many thanks
MikePerry
« Reply #1 on: March 09, 2005, 06:21:36 AM »
Hi
Within the AutoCAD Online Help File [F1] check out IndexCtl
Have a good one, Mike
jonesy
  • SuperMod
« Reply #2 on: March 09, 2005, 06:31:24 AM »
Thanks. That did the trick.
How do these things get changed. Its something I'd never heard of before
diarmuid
« Reply #3 on: March 09, 2005, 07:14:00 AM »
from my own experience, the template drawing that you are using has it set that way, or, you may be running an application such as a lisp etc...that is changing it, or you are using drawings from an outside source that is changing settings.
My best guess is its your template or a "rogue" lisp.
hth
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
jonesy
  • SuperMod
« Reply #4 on: March 09, 2005, 07:23:51 AM »
Mmm, I cant think it would be the template as they are used in all our drawings and this only happens on a couple of them, and with different clients.
The only thing I can do is keep my eyes open to see if I can figure out which lisp process changes it.
Thanks for your help
