Author Topic: Remember last inputed offset distance  (Read 1960 times)
RolandOrzabal
  • "memories fade but the scars still linger"
« on: October 29, 2012, 05:18:03 AM »
Hi to all, need a little help here...am new to lisp and i want the routine to remember the last inputed offset distance if the user runs the command again. My code keeps on resetting it to 1
(defun c:offset+ () (c:off+))
(defun c:off+ (/  *error* ent dist kwrd ofside dist1)
;; 24 october 2012 nod684
(defun  *error* (msg)
(command "._undo" "_end")
(setvar 'osmode osm)
(setvar 'cmdecho cmd1)
(command "._undo" "_begin")
(setq cmd1 (getvar 'cmdecho))
(setvar 'cmdecho 0)
(setq osm (getvar 'osmode))
(setvar 'osmode 923)
(prompt "\nSelect Object to Offset:   ")
(while (not ent)
(setq ent (ssget "_+.:S:L" '((0 . "*LINE,CIRCLE,ELLIPSE"))))
(initget (+ 1 2 4 64))
(setq dist (if dist dist1 1.0 ))
              (setq dist1 (cond ((getdist (strcat "\n Specify Offset Distance <" (rtos dist 2 2) ">: ")))
                                (T dist)
             (setq dist dist1)
(while (= ofside nil)
(setq ofside (getpoint "\nSide to offset on: "))
  (initget (+ 2 4) "Yes No")
  (setq kwrd (getkword "\nDelete source object? [Yes/No] <Yes>:  "))
  (if (/= kwrd "No")
    (setq kwrd "Yes")
   (command "offset" "erase" "no" dist ent ofside "")
  (if (eq kwrd "Yes")
    (command "erase" ent "")
  (*error* "")
  (princ "\nDone!")
(princ))
David Bethel
Re: Remember last inputed offset distance
« Reply #1 on: October 29, 2012, 05:44:55 AM »
Have you looked into the sysvar OFFSETDIST?  -David
R12 Dos - A2K
RolandOrzabal
« Reply #2 on: October 29, 2012, 05:57:36 AM »
thanks a lot!! i'll check on that :)
RolandOrzabal
« Reply #3 on: October 29, 2012, 06:02:28 AM »
Thanks a lot David! it's just what i need....working as i want it to be now :)
thanks again!
David Bethel
« Reply #4 on: October 29, 2012, 08:57:11 AM »
Glad it worked for you.  -David
R12 Dos - A2K
RolandOrzabal
« Reply #6 on: October 29, 2012, 11:04:08 PM »
Thanks again David and thanks for the info CAB
« Reply #7 on: October 30, 2012, 07:20:49 AM »
The following tutorial may also be of interest since you are looking to remember the last entered input:
http://lee-mac.com/promptwithdefault.html
RolandOrzabal
« Reply #8 on: October 31, 2012, 04:40:17 AM »
Thanks Lee!
