using Autodesk.AutoCAD.Internal;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
using System;
[assembly
: ExtensionApplication
(typeof(FOO
.Events))]
namespace FOO
public class Events : IExtensionApplication
void IExtensionApplication.Initialize()
Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("\nFOO events registered \n");
Register();
void IExtensionApplication.Terminate()
public static void Register()
DocumentCollection acDocs = acApp.DocumentManager;
Editor ed = acDocs.MdiActiveDocument.Editor;
try
foreach (Document doc in acDocs)
doc.CommandEnded -= doc_CommandEnded;
doc.CommandEnded += doc_CommandEnded;
acDocs.DocumentCreated -= acDocs_DocumentCreated;
acDocs.DocumentCreated += acDocs_DocumentCreated;
acDocs.DocumentActivated -= acDocs_DocumentActivated;
acDocs.DocumentActivated += acDocs_DocumentActivated;
Reconcile();
catch (System.Exception ex)
ed.WriteMessage("\n; error: " + ex.Message + " \n");
public static void acDocs_DocumentActivated(Object sender, DocumentCollectionEventArgs e)
if (e.Document != null)
Reconcile();
public static void acDocs_DocumentCreated(Object sender, DocumentCollectionEventArgs e)
Register();
public static void doc_CommandEnded(Object sender, CommandEventArgs e)
if (Utils.WcMatch(e.GlobalCommandName.ToUpper(),
"*CHSPACE,*MSPACE,*PSPACE,*LAYOUT_CONTROL,U,*UNDO,*VPMAX,*VPMIN"))
Reconcile();
public static bool PViewportActive(Document doc)
Editor ed = doc.Editor;
Database db = doc.Database;
Transaction tr =
db.TransactionManager.StartOpenCloseTransaction();
//db.TransactionManager.StartTransaction();
using (tr)
BlockTable bt =
(BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
if (btr.Name.ToUpper() == "*MODEL_SPACE")
return true;
else
return false;
public static void Reconcile()
Document doc = acDocs.MdiActiveDocument;
string tilemode = acApp.GetSystemVariable("TILEMODE").ToString();
// Model space
if (tilemode == "1")
ed.WriteMessage("\n** ModelSpace active ** \n");
else
// Pviewport
if (PViewportActive(doc))
ed.WriteMessage("\n** PViewport active ** \n");
// Paper space
else
ed.WriteMessage("\n** PaperSpace active ** \n");
