Author Topic: Insert MASKBLOCK at scale / Q-review my code please  (Read 1367 times)
« on: September 07, 2012, 03:22:02 PM »
Ugh! I was just forced to write a lisp (first one in a long time). It works but if anyone wants to clean it up or make any improvements...Please, feel free.
I found the getpointobj and stringstrip-end functions lying around so my job was a little easier.
This lisp is supposed to set the scale of a MASKBLOCK when a user picks a point. We use MASKBLOCKS for pipe and duct breaks (using AutoCAD MEP). -e.g. If the user picks the end of a duct this will find the scale the MASKBLOCK should be set to.
  1. (defun mask_add ( mask-block-name / x obj scale )
  2.
  3.   (defun getpointobj ( pt / obj pt )
  4.     (setvar "LASTPOINT" pt)
  5.     (cond
  6.       ((ssget pt)
  7.        (setq pt (ssname (ssget pt) 0))
  8.        (cond
  9.          ;; disable xref objects from the list of items.
  10.          ((assoc 2 (entget pt))
  11.           (not
  12.             (assoc
  13.               1
  14.               (tblsearch "BLOCK" (cdr (assoc 2 (entget pt)))))) )
  15.          ;; otherwise just create an object from picked point.
  16.          ((setq obj (vlax-ename->vla-object pt))))) )
  17.     obj )
  18.
  19.   (defun stringstrip-end ( str char )
  20.     ;; Strip the end of a string off.
  21.     ;; e.g. (StringStrip-End "This is a test" "i")
  22.     ;;   -> "This "
  23.     (defun liststriper (lst dec)
  24.       (if (= (car lst) dec)
  25.         (cdr lst) (liststriper (cdr lst) dec)))
  26.     (vl-list->string
  27.       (reverse (liststriper (reverse (vl-string->list str)) (ascii char)))))
  28.
  29.   (while (not (setq x (getpoint "\nSelect Point: ")))
  30.          (princ "\nYou did not select a point, please try again. "))
  31.
  32.   (setq obj (getpointobj x))
  33.
  34.   (cond
  35.     (obj
  36.       (cond
  37.         ((eq (vlax-get-property obj 'ShapeName) "Rectangular")
  38.          (setq scale
  39.                (atoi
  40.                  (stringstrip-end
  41.                    (vlax-get-property obj 'CrossSectionSize) "x"))))
  42.         ((eq (vlax-get-property obj 'ShapeName) "Round")
  43.          (setq scale
  44.                (atoi
  45.                  (vlax-get-property obj 'CrossSectionSize))))
  46.         )
  47.       (princ "\n ")
  48.       (command "_.maskadd" "NA" mask-block-name "x" scale "y" scale "z" scale x)
  49.       (while (eq (logand (getvar 'cmdactive) 1) 1)
  50.              (command PAUSE)) )
  51.     )
  52.   (princ)
  53.  )
