Author Topic: Civil 3D | Parcels  (Read 42696 times)
BlackBox
Re: Civil 3D | Parcels
« Reply #15 on: August 28, 2012, 06:54:29 PM »
Would it be logical then (conceptually speaking, as I'm on my iPhone), to employ a simple Command Reactor to 'cleanup' after import?
Unless the command is 'transparent' to the Reactor, monitoring the :vlr-CommandCancelled, :vlr-CommandEnded, and :vlr-CommandFailed Events should do the trick, methinks.
jawbreaker31
« Reply #16 on: July 16, 2014, 03:28:39 PM »
I guess I'm late to the Phantom Parcel party, but I would like for this to work in 2014.  Would it be possible to modify once more to add that into the lisp?  I tried on my end by adding ((vl-string-search "19.1" vrsn) "11.0") to the mix but that doesn't appear to do the trick. :-o
« Reply #17 on: July 16, 2014, 03:56:11 PM »
For 2014 use "10.3", not "11.0". For 2015 this will be "10.4"
BlackBox
« Reply #18 on: July 16, 2014, 05:19:47 PM »
Thanks Jeff - Code updated here (untested).
Cheers
CADventurer
« Reply #19 on: October 24, 2014, 10:03:19 AM »
I copied the latest code into an .lsp file and ran the command AECCDELETEPARCELS as indicated and selected ALL. but, it deleted 0 Parcels. Am I missing something?
Using 2014 SP2
BlackBox
« Reply #20 on: October 24, 2014, 10:17:07 AM »
... Am I missing something?
Not sure; do you have phantom parcels in your drawing?
If so, and the routine still doesn't work, try posting a drawing.
TonyatAlpha
« Reply #21 on: November 25, 2014, 11:00:02 AM »
I know this is a month late, but I've just found these "ghost" parcels in my template drawing file and would like to find a way to get rid of them.  I've tried using the lisp routine but it does not work.
Civil 3d 2014.  I have attached my template file. There are 1853 "ghost" parcels in the file.
should i just grab all my styles and settings and start with a fresh drawing.
any help would be greatly appreciated
« Reply #22 on: November 25, 2014, 11:25:10 AM »
I don't see any 'parcels' in either Site 1 or Survey Site, in this file attached.
« Reply #23 on: November 25, 2014, 11:25:53 AM »
what error message IF any do you get from the LISP file?
TonyatAlpha
« Reply #24 on: November 25, 2014, 11:29:20 AM »
It just says it deleted 0 objects, I don't get any error popups or anything
AECCDELETEPARCELS
Enter an option [All/Select]<Select>: A
Working, please wait... 0 parcels removed.
Command:
« Reply #25 on: November 25, 2014, 11:45:41 AM »
...I see no ghosts...
BlackBox
« Reply #26 on: November 25, 2014, 11:51:40 AM »
Michael,
After an offline conversation, I was emailed a drawing with phantom parcels, where the user reported similar issue using 2014 SP2.
I've personally tested their drawing, using 2014 SP2 and can confirm the failure now being reported (a failure that I did not experience previously)... The vl-Catch-All-Apply call is precluding the following error from being reported, when the Remove() Method is invoked on the oSites Object:
Civil 3D API: The parameter is incorrect.
I've verified that the API allows for either Name (string), Object reference as parameter for the Remove() Method (and have tried both variations), yet the call throws an exception nonetheless.
I've been exploring a .NET alternative, but do not have anything more conclusive to add at this time.
BlackBox
« Reply #27 on: November 25, 2014, 11:54:21 AM »
That's kind of the point... 1800+ Parcels selected with QSELECT Command, Select All option.
« Reply #28 on: November 25, 2014, 11:55:02 AM »
let me test again...
« Reply #29 on: November 25, 2014, 12:00:55 PM »
hmm, sucks that now the fix for this break in the application is NOW broken thanks to whatever fix they (autodesk) affected in SP2
