Author Topic: ReadDwgFile  (Read 1480 times)
WOWENS
ReadDwgFile
« on: August 09, 2012, 11:40:05 AM »
is there a way to see if the drawing and or database is already open before using ReadDwgFile?
Humbertogo
Re: ReadDwgFile
« Reply #1 on: August 09, 2012, 12:44:41 PM »
with FileShare.Read
MexicanCustard
Re: ReadDwgFile
« Reply #2 on: August 09, 2012, 01:43:17 PM »
This is the way I  check to see if any file is open before working on it.
private bool IsFileLocked(FileInfo file)
            FileStream stream = null;
            try
                stream = file.Open(FileMode.Open, FileAccess.ReadWrite, FileShare.None);
            catch (Exception)
                return true;
                if (stream != null)
                    stream.Close();
            return false;
Then call it like.
if (IsFileLocked(new FileInfo(dwgName)))
WOWENS
Re: ReadDwgFile
« Reply #3 on: August 09, 2012, 02:21:01 PM »
thank you
