Download the 30 day trial of Full AutoCAD.
Quote from: sugarCAD on August 14, 2012, 02:04:43 PMDownload the 30 day trial of Full AutoCAD. ....However, this IS another good oportunity to record the hours required to use the "manual" "LT" "work around" and compare it to the seconds it could've taken you with Full AutoCAD.
Quote from: M-dub on August 14, 2012, 02:11:12 PMQuote from: sugarCAD on August 14, 2012, 02:04:43 PMDownload the 30 day trial of Full AutoCAD. ....However, this IS another good oportunity to record the hours required to use the "manual" "LT" "work around" and compare it to the seconds it could've taken you with Full AutoCAD.Agreed
Quote from: ronjonp on August 14, 2012, 02:18:50 PMQuote from: M-dub on August 14, 2012, 02:11:12 PMQuote from: sugarCAD on August 14, 2012, 02:04:43 PMDownload the 30 day trial of Full AutoCAD. ....However, this IS another good oportunity to record the hours required to use the "manual" "LT" "work around" and compare it to the seconds it could've taken you with Full AutoCAD.Agreed Eventually, you WILL have enough justification. This is fact, it is, it is.
