I have lots multileaders with block and attributes in my drawing.
What I want to do is to go through all objects in the drawing and then update the attribute of multileaders.
I know C# a little, here is my code, does anybody know how to do this?
namespace Update_Mleader
public class Update_Mleader
[CommandMethod("UpdateMleaderAttr")]
public void UpdateMleader()
Database db = doc.Database;
Editor ed = doc.Editor;
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
foreach (ObjectId entId in btr)
Entity ent = tr.GetObject(entId, OpenMode.ForRead) as Entity;
if (ent != null)
if (ent.GetType() == typeof(MLeader))
// how to update the attribute of the mleader?
// example, if the attribute Tag is "XCODE"
// and i want to update the TextString to "100"
tr.Commit();
ed.Regen();
