Thanks Michael and Renderman,
After thinking though the possibilities, I'm going with recomending having the remote office creating the surface, and exporting the XML, shipping both a styled surface drawing and the XML to the local shop.
Here's my thinking...
First off, the end user's will be engineering interns, lacking experience and judgement. While leaving the surface drawing alone and datareferencing it into the sheets is a Good Thing (TM), teaching Drefs in 5 minutes or less is not something I can do comfortably. Maybe if Dref's worked though Design Center style drag and drop.....
Evidently, Xrefing in the surface drawing is not trustable. contours disappear in viewports for no explainable/correctable reason - so I'm calling that a bug in the program. Maybe just too big an area is involved and memory leaks are causing problems, maybe corrupt viewports, maybe something else. Point is, it's unreliable. Plus, it can't be labeled/queried or styled since it's an Xref.
I can however, teach an intern how to insert a LandXML file and create a surface in the current drawing to label and use in a background, in 5 minutes. And, presuming the XML file is retained, it can be rebuilt when something goes flaky. Shouldn't need the XML in theory, but stuff happens, c3d crashes, drawings get corrupt, so keeping the XML handy, treating it as the 'master' version, gives me a feeling of security that I can recover to the 'last known good' no matter what else happens.
cheers,
