Author Topic: ALIGNED LISP  (Read 9637 times)
Fabricio28
ALIGNED LISP
« on: August 03, 2012, 12:36:15 PM »
 :mrgreen:
Thanks in advance.
 Fabricio
Fabricio28
Re: ALIGNED LISP
« Reply #1 on: August 03, 2012, 12:36:44 PM »
Hey guys,
 I need a lisp that calculates the distance between two points and put the distance in the midpoint above the line.
 The aligned command is a block, I need a simple text for the distance.
 Please, help me out...
Fabricio28
Re: ALIGNED LISP
« Reply #2 on: August 03, 2012, 12:50:26 PM »
Sorry guys...
 I've found this lisp.
Thanks anyway
 :lmao:
Re: ALIGNED LISP
« Reply #3 on: August 03, 2012, 12:59:29 PM »
Here is a very simple fully-commented example that you (and maybe others) can learn from:
  1. (defun c:dmid ( / an di p1 p2 tp ) ;; Define function, localise variables
  2.     (if ;; if the following test expression returns a non-nil value
  3.         (and ;; all of the following expressions must return a non-nil value
  4.              ;; Collect the first point from the user, assign to p1
  5.              (setq p1 (getpoint "\nSpecify First Point: "))
  6.              ;; Collect the second point from the user, rubber-band to p1, assign to p2
  7.              (setq p2 (getpoint "\nSpecify Second Point: " p1))
  8.         ) ;; end and
  9.         (progn ;; Evaluate the following expressions as the 'then' expression for the if function
  10.             ;; Calculate the distance between the points
  11.             (setq di (distance p1 p2)
  12.             ;; Calculate the angle between the points
  13.                   an (angle p1 p2)
  14.             ;; Calculate the point for the Text
  15.                   tp (polar
  16.                          (polar p1 an (/ di 2.0)) ;; Line midpoint
  17.                          (+ an (/ pi 2.0))  ;; Perpendicular to Line
  18.                          (getvar 'textsize) ;; Offset by text height
  19.                      )
  20.             )
  21.             ;; Create the line between the points
  22.             (entmake
  23.                 (list
  24.                    '(0 . "LINE") ;; Entity type
  25.                     (cons 10 p1) ;; Start point
  26.                     (cons 11 p2) ;; End point
  27.                 ) ;; end list
  28.             ) ;; end entmake
  29.             ;; Create the text to display the distance
  30.             (entmake
  31.                 (list
  32.                    '(0 . "TEXT") ;; Entity type
  33.                     (cons 10 tp) ;; Insertion Point
  34.                     (cons 11 tp) ;; Alignment POint
  35.                     (cons  1 (rtos di)) ;; Content
  36.                     (cons 40 (getvar 'textsize)) ;; Height
  37.                     (cons 50 an) ;; Angle
  38.                    '(72 . 1) ;; Center
  39.                    '(73 . 2) ;; Middle
  40.                 ) ;; end list
  41.             ) ;; end entmake
  42.         ) ;; end progn
  43.     ) ;; end if
  44.     (princ) ;; Suppress the return of the last evaluated expression
  45. ) ;; end defun
  46. (princ) ;; Suppress return of expression evaluated on load
Many improvements could be made to account for text readability and UCS.
Fabricio28
Re: ALIGNED LISP
« Reply #4 on: August 03, 2012, 01:34:19 PM »
Please Lee,
Could you explain how use this lisp??
Re: ALIGNED LISP
« Reply #5 on: August 03, 2012, 02:16:41 PM »
The program is as you described in Reply#1  :?
Fabricio28
Re: ALIGNED LISP
« Reply #6 on: August 03, 2012, 02:33:54 PM »
Yes Lee, I know...
What's the commando this routines??
I apploaded the lisp, but I can't use it.
Kind Regards
owenwengerd
Re: ALIGNED LISP
« Reply #7 on: August 03, 2012, 03:04:44 PM »
Yes Lee, I know...
Kind Regards
Dude, seriously? This is a programming group, not a group for requesting free lisp routines. IMO, if you post here, you should be a programmer or learning to become one. Your response indicates that you're neither learned nor interested in investing any effort in learning, which is rude and insulting to the rest of the members. Lee Mac wrote a custom lisp routine to your specification for free. He probably skipped some other important activity so he could spend an hour or two to help you out. Now you can't be bothered to invest 10 minutes to read the code and do some internet research in order to learn how to use it? I think you owe Lee Mac an apology.
Re: ALIGNED LISP
« Reply #8 on: August 03, 2012, 03:05:41 PM »
The command for the function is dmid. For future reference, you can determine the command for a program by looking at the string following a 'c:' prefix in a defun expression, in this case, we have c:dmid, so the command is dmid (distance at midpoint)
Fabricio28
Re: ALIGNED LISP
« Reply #9 on: August 03, 2012, 03:33:08 PM »
Lee,
I'm sorry to bother you, but I didn't get it.
I pasted the code  in Visual Lisp editor and I appload the file.
I've tried use dmid, but the AutoCad don't recognize the command.
I'm doing something worng
Take a look in dmid.lisp, please.
Best Regards
Re: ALIGNED LISP
« Reply #10 on: August 03, 2012, 03:39:22 PM »
Looks like the numbers are copied to each line of the code for some reason :? What browser are you using?
Try the attached file.
Fabricio28
Re: ALIGNED LISP
« Reply #11 on: August 03, 2012, 03:43:00 PM »
The code are copied in the single line in the Visual Lisp.
I don't know why. So I had to put in order the numbers.
I'm using Internet Explorer.
Fabricio28
Re: ALIGNED LISP
« Reply #12 on: August 03, 2012, 03:50:28 PM »
Thanks ronjonp,
Your lisp works.
I don't know where was my mistake. Thanks anyway
Thanks Lee,
Your routine is fantastic. It was exactly I needed
Thanks all for you!
me :ugly: hahahahaha
irneb
Re: ALIGNED LISP
« Reply #13 on: August 04, 2012, 04:17:15 AM »
I think this was it:
In Chrome/FireFox when I select the code in Lee's post it doesn't select the numbers to the left of each line.
If you want to stick with using IE, then I'd suggest you install something like Notepad++. It has a feature to select columns of text - which would make it a lot simpler to remove the line numbers from the front of each line in the LSP file.
Edit: Just tested. IE is even worse than I thought  :ugly: It doesn't even copy-paste the lines as lines. Copying Lee's code to normal Notepad puts everything (including the line numbers) all on one single line. Tht's going to cause even greater issues due to the comments in the code. You won't even be able to use VLIDE's autoformat to try and fix this. See the screen captures
« Last Edit: August 04, 2012, 04:30:30 AM by irneb »
GP
  • Vercelli, Italy
Re: ALIGNED LISP
« Reply #14 on: August 04, 2012, 04:36:28 AM »
Or quote the message, select code, copy and paste.  :-)
