Author Topic: =={challenge}==Find k th smallest element  (Read 6426 times)
highflyingbird
  • Later equals never.
« on: June 28, 2012, 01:00:46 AM »
Given a set of "n" unordered numbers we want to find the "k th" smallest number. (k is an integer between 0 and n-1). Especially,find the median.
Notice: becareful when you use "vl-sort",because it will remove the duplicate elements.
about median ,see here .
here is my code:
  1. ;;;============================================================
  2. ;;;Highflybird                     2012.06.28.in Shenzhen,China
  3. ;;;------------------------------------------------------------
  4. ;;;Function: find the "k th" smallest number in a set of "n"
  5. ;;;          unordered numbers or other elements
  6. ;;;Arguments:lst  -- an unordered list
  7. ;;;          low  -- the low position
  8. ;;;          high -- the high position
  9. ;;;          n    -- Index of elements will be found(0 to n-1)
  10. ;;;Return:The element will be found
  11. ;;;------------------------------------------------------------
  12. ;;;Example: (H:kth '(2 1 3 2 7 12 5 3 9) 0 8 6)  ==> 7
  13. ;;;============================================================
  14. (defun H:kth (lst low high n / Greater Less Index Copy First)
  15.   (if (cdr lst)
  16.     (progn
  17.       (setq First (car lst))                                    ;The first one as pivot.
  18.       (setq Copy lst)                                           ;Copy the list
  19.       (while (setq Copy (cdr Copy))                             ;CDR the copy list
  20.         (if (> First (car Copy))                                ;Get the first one in copy list and Compare to the pivot
  21.           (setq Less (cons (car Copy) Less))                    ;If less,add it into the less part
  22.           (setq Greater (cons (car Copy) Greater))              ;If greater, add it into the greater part
  23.         )
  24.       )
  25.       (setq Index (+ (length Less) low))                        ;The position of the first element
  26.       (cond
  27.         ( (= Index n) First)                                    ;End the recursion.
  28.         ( (< Index n) (H:kth Greater (1+ Index) high n))        ;Recurse the greater part
  29.         (t (H:kth Less low (1- Index) n))                       ;Recurse the Less part
  30.       )
  31.     )
  32.     (car lst)                                                   ;Just one element or nil
  33.   )
  34. )
  35.
test ,find  6 th element.
==> 7
« Last Edit: June 28, 2012, 01:15:33 PM by HighflyingBird »
I am a bilingualist,Chinese and Chinglish.
Re: =={challenge}==Find k th smallest element
« Reply #1 on: June 28, 2012, 03:24:52 AM »
Just for fun, rewrite that using variable names that represent the value they hold and see how much easier it is to read
... for us now and for you next week :)
Regards
kdub
added:
and naming the method MeanCalculator or MedianCalculator may help too :)
« Last Edit: June 28, 2012, 03:28:38 AM by Kerry »
highflyingbird
« Reply #2 on: June 28, 2012, 03:50:05 AM »
Regards
kdub
added:
Thank you very much. Very good advice.
Regards
highflyingbird
« Reply #3 on: June 28, 2012, 07:21:56 AM »
  1. (defun f ( l n ) (nth (nth n (vl-sort-i l '<)) l))
_$ (f '(2 1 3 2 7 12 5 3 9) 6)
7
irneb
« Reply #4 on: July 09, 2012, 11:04:51 AM »
I think Lee's is going to be the most efficient, but just for fun:
  1. (defun kth-smallest  (lst k / m slst)
  2.   (if lst
  3.     (progn (setq m    (apply 'min lst)
  4.                  slst (vl-remove-if-not '(lambda (a) (= a m)) lst))
  5.            (cond ((<= k 0) (car slst))
  6.                  ((< k (length slst)) (nth k slst))
  7.                  (t (kth-smallest (vl-remove-if '(lambda (a) (= a m)) lst)
  8.                                   (- k (length slst))))))))
Though it's obviously extremely inefficient  :ugly: , in comparison! Not to mention if k is too large (20000+) the recursion might error out on stack space.
Though it does allow for order of duplicates, whereas the sorting does not. Consider this:
_$ (f '(2 1 3 7. 2 7 12 5 3 9) 6)
7
_$ (f '(2 1 3 7. 2 7 12 5 3 9) 7)
7.0
_$ (kth-smallest '(2 1 3 7. 2 7 12 5 3 9) 6)
7.0
_$ (kth-smallest '(2 1 3 7. 2 7 12 5 3 9) 7)
7
ribarm
  • Marko Ribar, architect
« Reply #5 on: July 09, 2012, 01:01:46 PM »
My opinion is that vl-sort-i function is correct - integer is smaller than real, (7<7.0) so Lee's code wins...
M.R.
M.R. on Youtube
irneb
« Reply #6 on: July 09, 2012, 04:12:41 PM »
M.R.
Not too sure I follow. AFAICT:
Command: (< 7.0 7)
nil
Command: (< 7 7.0)
nil
Command: (= 7 7.0)
T
Thus to me it seems that the order of equal items is the defining factor.
All I can think of to support your claim is that an integer uses less bits in RAM to store the same number.
Anyhow, the vl-sort doesn't actually do what you think. The quick-sort algorithm doesn't order equal items in any particular order. It's one of it's drawbacks. Thus if the list order was slightly different, the vl-sort idea could give a different result.
Edit: Obviously that's splitting hairs though. In this case the OP does state that the list contains only integers, so this idea is moot anyway.
« Last Edit: July 09, 2012, 04:35:49 PM by irneb »
irneb
« Reply #7 on: July 09, 2012, 04:24:04 PM »
Anyhow, here's my iterative version:
  1. (defun kth-smallest-i  (lst k / n m)
  2.   (while (and (not n) lst)
  3.     (setq m (apply 'min lst)
  4.           lst (vl-remove-if '(lambda (a) (if (= a m) (progn (if (= (setq k (1- k)) -1) (setq n a)) t))) lst)))
  5.   n)
Still not in the same speed league as Lee's though.
Edit: Stupid mistake  :-[
« Last Edit: July 09, 2012, 04:38:23 PM by irneb »
highflyingbird
« Reply #8 on: July 09, 2012, 06:58:51 PM »
M.R.
Actually, Although Lee's code is very short, but my code is faster.
Especially for a large number list. because  "nth" will take some time ,it's very different from  C++ or VB.
_$ (h:kth '(7 7.0 7 7 7.0) 0 4 3)
7
Lee's
_$ (f '(7 7.0 7 7 7.0) 3)
7.0
« Last Edit: July 09, 2012, 07:05:30 PM by HighflyingBird »
ribarm
« Reply #9 on: July 10, 2012, 02:21:46 AM »
Irne, I think you're wrong, vl-sort-i does really sort numbers by its exact order - here is example with negative numbers (now real is smaller than integer)
(setq lst '(1 -1.0 2 3))
(f lst 0) => -1.0
(f lst 1) => 1
And I think that this more RAM for storing real number is exactly the difference between real and integer, so (-1.0<1) just like it should be (order of numbers inside list is totally irrelevant for determination of smallest number)...
M.R.
M.R. on Youtube
irneb
« Reply #10 on: July 10, 2012, 02:40:42 AM »
(f lst 0) => -1.0
(f lst 1) => 1
M.R.
Of course -1.0 is smaller than +1 ... the real is negative white the integer is positive! ... that's not what I'm saying (see your own previous post - you mentioned 7 and 7.0 ... both positive!). What I was referring to is when both are the SAME sign: +1.0 is EQUAL to +1
The vl-sort-i does not order EQUAL items in any order, see here
_$ (f '(1 1.0 2) 0)
1.0
_$ (f '(1.0 1 2) 0)
1
_$ (f '(1.0 1 2 1) 0)
1
_$ (f '(1 1.0 2 1) 0)
1
While usually this doesn't matter, it's when your comparison only takes note of a portion of the data items - then you get a sort-of random ordering of "equal" items among each other.
irneb
« Reply #11 on: July 10, 2012, 02:51:54 AM »
As for speed:
_$ (setq lst '(2 1 3 2 7 12 5 3 9) low (apply 'min lst) high (apply 'max lst) k (/ (length lst) 2))
4
_$ (QuickBench '((H:kth lst low high k) (LM:Kth lst k) (IB:kth-smallest-r lst k) (IB:kth-smallest-i lst k)))
Benchmarking .... done for 32768 iterations. Sorted from fastest.
Statement                                Increment  Time(ms) Normalize  Relative
(LM:KTH LST K)                               32768      1544      1544      6.79
(H:KTH LST LOW HIGH K)                       16384      1107      2214      4.74
(IB:KTH-SMALLEST-I LST K)                     4096      1154      9232      1.14
(IB:KTH-SMALLEST-R LST K)                     4096      1311     10488      1.00
_$ (setq lst '(2 1 3 2 7 12 5 3 9 4 6 2 8 10 1 7 4 8 3 6 3 4 6 3 6 87 34 3 7 4 32 2 2 6 7 8 4 3 6 7 4 348 3 24 32) low (apply 'min lst) high (apply 'max lst) k (/ (length lst) 2))
22
Benchmarking .... done for 8192 iterations. Sorted from fastest.
(LM:KTH LST K)                                8192      1154      1154      5.67
(H:KTH LST LOW HIGH K)                        4096      1529      3058      2.14
(IB:KTH-SMALLEST-I LST K)                     2048      1327      5308      1.23
(IB:KTH-SMALLEST-R LST K)                     2048      1637      6548      1.00
_$ (setq lst nil)
nil
_$ (length (repeat (RandomMinMax 0 10000 nil) (setq lst (cons (RandomMinMax 0 200 nil) lst)))))
6731
_$ (setq low (apply 'min lst) high (apply 'max lst) k (/ (length lst) 2))
3365
Benchmarking .... done for 64 iterations. Sorted from fastest.
(H:KTH LST LOW HIGH K)                          64      1031      1031     26.61
(LM:KTH LST K)                                  32      1187      2374     11.56
(IB:KTH-SMALLEST-I LST K)                        8      2013     16104      1.70
(IB:KTH-SMALLEST-R LST K)                        4      1715     27440      1.00
Yes, yours' does go faster on long lists.
irneb
« Reply #12 on: July 10, 2012, 03:05:27 AM »
Sorry ... no I misunderstood what your low and high arguments were about! Though it's still faster:
_$ (setq lst nil)
nil
_$ (length (repeat 10000 (setq lst (cons (RandomMinMax 0 200 nil) lst))))
10000
_$ (setq low 0 high (length lst) k (/ (length lst) 2))
5000
Benchmarking .... done for 32 iterations. Sorted from fastest.
(H:KTH LST LOW HIGH K)                          32      1296      1296     13.31
(LM:KTH LST K)                                  32      1824      1824      9.46
(IB:KTH-SMALLEST-I LST K)                        4      1404     11232      1.54
(IB:KTH-SMALLEST-R LST K)                        2      1078     17248      1.00
ribarm
« Reply #13 on: July 10, 2012, 03:58:58 AM »
Irne, what I ment to say (my "typo" mistake) :
(setq lst '(-1 -1.0 2 3))
(f lst 0) => -1.0
(f lst 1) => -1
So -1.0<-1...
check it on your own... I thaught you'll correct me...
M.R.
M.R. on Youtube
ribarm
« Reply #14 on: July 10, 2012, 04:45:20 AM »
Yes, I see it now :
(f '(1 1.0 2) 0) => 1.0
But now I've changed Lee's code :
  1. (defun f ( lst n )
  2.   (nth (nth n (vl-sort-i lst '<=)) lst)
  3. )
  4.
And now order of equal elements is preserved from original list - correct me if I'm wrong...
(f '(1.0 1 2) 0) => 1.0
(f '(-1 -1.0 2 3) 0) => -1
(f '(-1.0 -1 2 3) 0) => -1.0
M.R.
M.R. on Youtube
