Author Topic: ATTRIBUTE EDIT-COMBINING TWO ROUTINES  (Read 2285 times)
TJAM51
« on: February 25, 2005, 12:07:34 PM »
I am seeking a way to combine the following routines. I need a specific sequence....angle change first then position change next.
FIRST ROUTINE
;;;Attribute angle change
(defun c:aac ()
(setq atta(getint "\nEnter new attribute angle: "))
(command "attedit" "y" "*" "*" "*" "c" pause pause)
(while
(= 1 (logand (getvar "cmdactive") 1))
(command "a" atta "n")
);;; end while
);;; end lisp
SECOND ROUTINE
(defun c:atp (/ $n z zz zz1 cmd)
(setq cmd (getvar "cmdecho"))
(setvar "cmdecho" 1)
         (setq $n 1)
          (while
           (> $n 0)
            (setq z (nentsel "\nSelect an Attribute to be REPOSITIONED<or ENTER when done>: "))
            (if (= z nil)(setq $n 0))
              (= z nil)(prompt "\nD O N E")
              (setq zz (entget (car z)))
              (setq zz1 (cdr (assoc 0 zz)))
                   (/= zz1 "ATTRIB")
                     (prompt "\nSorry selected entity - not an ATTRIBUTE")
                        (= z nil)
                        (command "attedit" "" "" "" "" z "p" pause "n")
                        );if
                     );progn
                );if
              );progn
             );if
           );progn
          );while
(setvar "cmdecho" cmd)
Andrea
« Reply #1 on: February 28, 2005, 08:42:43 AM »
(defun c:aac ()
(while
);;; end while
(atp)
);;; end lisp
;;SECOND ROUTINE
(defun atp (/ $n z zz zz1 cmd)
(setq $n 1)
(while
(> $n 0)
(/= zz1 "ATTRIB")
(= z nil)
);if
);progn
);if
);progn
);if
);progn
);while
Keep smile...
TJAM51
« Reply #2 on: February 28, 2005, 09:01:31 AM »
Thank you very much......
