Author Topic: How to avoid direction of picking points?  (Read 6240 times)
HasanCAD
« on: June 10, 2012, 07:49:35 AM »
How to make always left point as pt and right point as p2 even I picked from right to left?
(and (setq p1 (getpoint "\nPick first point."))
     (setq p2 (getpoint p1 "\nPick second point."))
Re: How to avoid direction of picking points?
« Reply #1 on: June 10, 2012, 08:04:56 AM »
(if (< (car p2) (car p1))
    (mapcar 'set '(p1 p2) '(p2 p1))
  1. (if (< (car p2) (car p1))
  2.     (mapcar 'set '(p1 p2) (list p2 p1))
  3. )
Or
  2.     (setq tmp p1 p1 p2 p2 tmp)
  3. )
« Last Edit: June 10, 2012, 09:18:58 AM by Lee Mac »
pBe
« Reply #2 on: June 10, 2012, 08:17:58 AM »
  1. (and (setq pk nil  p1 (getpoint "\nPick first point."))
  2.      (while (and (not pk) (setq p2 (getpoint p1 "\nPick second point.")))
  3.                 (if (< (car p1) (car p2))
  4.                         (setq pk T) (princ "\nOut of bounds:")
  5.                         )(princ)
  6.                 )
  7.      )
irneb
« Reply #3 on: June 10, 2012, 08:44:24 AM »
  2.     (mapcar 'set '(p1 p2) '(p2 p1))
  3. )
Just a slight mod on your code:
  2.   (mapcar 'set '(p1 p2) (list p2 p1)))
Otherwise P1 equals the symbol P2, and P2 equals the symbol P1. Even if you then use eval, you simply get:
  1. (eval p1) ;Returns P1
  2. (eval (eval p1)) ;Returns P2
  3. (eval p2) ;Returns P2
  4. (eval (eval p2)) ;Returns P1
You've effectively removed the actual point values and replaced them with symbols.
« Reply #4 on: June 10, 2012, 09:17:59 AM »
Oops! Yes, that's what I meant to write - thanks Irneb  :-)
HasanCAD
« Reply #5 on: June 10, 2012, 09:43:16 AM »
  3. )
perfect but with little bit change
  2.                (setq tmp p1 p1 p2 p2 tmp )
  3.               (setq p1 p1 p2 p2 )
  4.              )
irneb
« Reply #6 on: June 10, 2012, 09:44:25 AM »
No prob ... we all make mistakes ... me quite a lot!  :-[ You had the idea, I just fixed a minor typo!
I think this is one of those cases where using mapcar in a different manner than it's "supposed" to be used makes for more elegant code. I'm trying to imagine how to do this with foreach instead, but the code becomes convoluted since you first need to combine 2 lists in order to use them both together in foreach. Something like this:
  2.   (foreach item (mapcar 'list '(p1 p2) (list p2 p1))
  3.     (apply 'set item)))
"Supposedly" more correct, but sooo much more typing, and gaining nothing in return! :ugly:
Cudos for the most elegant and most "functional" version!
irneb
« Reply #7 on: June 10, 2012, 09:45:52 AM »
  4.         )
You don't strictly need to do that, p1 already equals the most left pick-point in the else portion. No need to set it to it's own value again.
« Reply #8 on: June 10, 2012, 10:01:20 AM »
Thanks, but I'm afraid I can't take all the credit for that solution  :-)
HasanCAD
« Reply #9 on: June 10, 2012, 10:10:53 AM »
Try this will give an error
       (setq p1 p1 p2 p2)
     (setq *L* (cond ((getint (strcat "\nWhat is HIGH Point <" (itoa (setq *L* (cond (*L*)
    (160)))) ">: " ))) (*L*)))
     (setq *c* (cond ((getint (strcat "\nWhat is LOW Point <" (itoa (setq *c* (cond (*c*) (35)))) ">: " ))) (*c*)))
     (setq step 1000)
     (setq dist (distance p1 p2))
     (setq #pt (fix (/ (/ dist step) 2)))
     (setq ang (angle p1 p2))
     (setq pang (+ ang (/ pi 2.)))
     (setq idx 1)
     (setq mp (list (/ (+ (car p1) (car p2)) 2)
    (/ (+ (cadr p1) (cadr p2)) 2))))
HasanCAD
« Reply #10 on: June 10, 2012, 10:12:25 AM »
Any way
Thanks all for the flood of information I got ;)
« Reply #11 on: June 10, 2012, 10:13:24 AM »
Tip: Learn how to use multiple:
  1. (if <test expression>
  2.     <then expression>
  3.     <else expression>
  4. )
Over a single:
  1.     <expression>
  2.     <expression>
  3.     <expression>
  4.     ....
  5. )
HasanCAD
« Reply #12 on: June 10, 2012, 10:23:59 AM »
...[/code]
And in previous reply is a test expression of IF function
(if (and (setq p1 (getpoint "\nPick first point."))
       (setq p1 p1 p2 p2)
     (setq step 1000)
     (setq idx 1)
« Last Edit: June 10, 2012, 10:29:01 AM by HasanCAD »
irneb
« Reply #13 on: June 10, 2012, 10:31:56 AM »
The point is you don't need to check if you've got the points swapped around correctly in order to continue. There's 2 ways of going about it without needing to reset variables to their already set values.
Option 1:
  1. (if (and (setq p1 (getpoint "\nPick first point."))
  2.          (setq p2 (getpoint p1 "\nPick second point."))
  3.          (if (< (car p2) (car p1))
  4.            (setq tmp p1
  5.                  p1  p2
  6.                  p2  tmp)
  7.            t)
  8.          (setq *L* (cond ((getint (strcat "\nWhat is HIGH Point <"
  9.                                           (itoa (setq *L* (cond (*L*)
  10.        (160))))
  11.                                           ">: ")))
  12.                          (*L*)))
  13.          ...
  14.          )
  15.   (progn ...
  16.          ))
Or a slightly more "correct" Option 2:
  3.          (progn (if (< (car p2) (car p1))
  4.                   (setq tmp p1
  5.                         p1  p2
  6.                         p2  tmp))
  7.                 (setq *L* (cond ((getint (strcat "\nWhat is HIGH Point <"
  8.                                                  (itoa (setq *L* (cond (*L*)
  9.        (160))))
  10.                                                  ">: ")))
  11.                                 (*L*)))
  12.          )
  13.          ...
  14.          )
  15.   (progn ...
  16.          ))
« Reply #14 on: June 10, 2012, 12:01:25 PM »
Late to the party.
  (if (< (/ pi 2) (angle p1 p2) (* pi 1.5))
