Author Topic: Migrating From AutoCAD 2012 to 2013  (Read 14336 times)
CADbloke
  • Crash Test Dummy
Re: Migrating From AutoCAD 2012 to 2013
« Reply #15 on: June 27, 2012, 07:37:39 AM »
I have yet to try it but this might be handy for maintaining multiple projects using the same source code: http://msdn.microsoft.com/en-us/library/ff648745.aspx - Project Linker: Synchronization Tool on MSDN.
The Visual Studio Gallery page is at http://visualstudiogallery.msdn.microsoft.com/5e730577-d11c-4f2e-8e2b-cbb87f76c044 for downloading. I noticed in the Q&A that there may be an easy way to get it running in VS 2012 RC
This extension was made specifically for WPF / Silverlight project code sharing so things like XAML files may misbehave.
Caveat emptor !
... Edit ... This StackOverflow answer about modifying a project file to compile other sources using wildcards is also interesting (and more lightweight) http://stackoverflow.com/a/9563860/492
... Edit ... Thanks for clarifying Jeff. It was pretty late at night (for me) when I added that. :)
« Last Edit: June 27, 2012, 11:44:19 PM by CADbloke »
« Reply #16 on: June 27, 2012, 10:15:57 AM »
'Add as Link' already mentioned in 2nd reply here, adds the same thing to the .csproj file.
CADbloke
  • Crash Test Dummy
« Reply #17 on: July 02, 2012, 02:38:15 AM »
Firstly: I'm in the middle of trying this, so treat it as an incomplete work in progress.
The wildcards answer (http://stackoverflow.com/a/9563860/492)  I linked to previously automatically adds and removes all source files to/from the target project so you don't miss them. Note if you want to miss a specific file or more than you can name them using "Exclude".
<ItemGroup>
    <Compile Include="..\_Src\**\*.cs" Exclude = "..\_Src\Properties\AssemblyInfo.cs">
      <Link>Src\%(RecursiveDir)%(Filename)%(Extension)</Link>
    </Compile>
   </ItemGroup>
This shows up in the target solution under a folder named "Src". To show the files in the root of the target project you just use ...
<ItemGroup>
      <Link>%(RecursiveDir)%(Filename)%(Extension)</Link>
    </Compile>
   </ItemGroup>
More info on this at http://msdn.microsoft.com/en-us/library/ms164283(v=vs.90).aspx & http://msdn.microsoft.com/en-us/library/ms171453(v=vs.100).aspx & http://msdn.microsoft.com/en-us/library/ms171454(v=vs.100).aspx.
This works in both VS2012RC & VS2010sp1 although I had to close & re-open the solution in both for any file additions or deletions in the _Src project to propagate into the linked project(s).
I am creating projects for the various versions (generally milestone versions like 2006, 07, 10 & 13) which have the relevant references to their DLLs, and a separate project called "_Src", which has a reference to 2007 because it has the leanest feature set, for the actually source code that is used by all of the other projects when they build.
I don't want to build the _Src project. How do I stop that?:
  • Right-click the solution Root node in the Solution Explorer,
  • go to configuration properties -> Configuration.
  • Change the configuration dropdown (top left on VS2012) to "All Configurations",
  • then untick the build checkbox for the source project.
I am trying this in both VS2010sp1 & VS2012RC at the same time (different computers) and so far, so good. My real goal is to also share the _Src code with a stand-alone app using the ODA Teigha.NET (classic) library. Yeah, because my life is not already complicated enough.
There are various other things to watch for like target framework, x86/x64 (I got a build warning on v2007 for this but it usually doesn't matter AFAIK), changing method names (I'll use Tony's extension methods for this), a universale AssemblyInfo etc. I'll update as I crash into other things. As I said, it's a work in progress. Any input is most welcome.
cheers
Ewen
Update - this is the latest rendition of my XML to specify what is compiled in the project that references the source code:
  <ItemGroup>
    <!--This is where to include / exclude source code files-->
    <Compile Include="..\_Src\**\*.*" Exclude="..\_Src\Properties\AssemblyInfo.cs;..\_Src\bin\**\*.*;..\_Src\obj\**\*.*;..\_Src\**\*.csproj;..\_Src\**\*.user;..\_Src\**\*.vstemplate;..\_Src\readme.txt;..\_Src\**\*.lsp;..\_Src\**\*.scr">
    </Compile>
    <Compile Include="Properties\AssemblyInfo.cs" />
  </ItemGroup>
The source project has an AssemblyInfoForAllProjects.cs and each project has an AssemblyInfo.cs with just the AssemblyTitle, AssemblyDescription & COM GUID in it. The rest of the info, common to every project inthe solution, lives in AssemblyInfoForAllProjects.cs
« Last Edit: September 08, 2012, 09:20:12 AM by CADbloke »
