Firstly: I'm in the middle of trying this, so treat it as an incomplete work in progress.
'Add as Link' already mentioned in 2nd reply here, adds the same thing to the .csproj file.
The wildcards answer (
http://stackoverflow.com/a/9563860/492) I linked to previously
automatically adds and removes all source files to/from the target project so you don't miss them. Note if you want to miss a specific file or more than you can name them using "Exclude".
<ItemGroup>
<Compile Include="..\_Src\**\*.cs" Exclude = "..\_Src\Properties\AssemblyInfo.cs">
<Link>Src\%(RecursiveDir)%(Filename)%(Extension)</Link>
</Compile>
</ItemGroup>
This shows up in the target solution under a folder named "Src". To show the files in the root of the target project you just use ...
<ItemGroup>
<Link>%(RecursiveDir)%(Filename)%(Extension)</Link>
</Compile>
</ItemGroup>
More info on this at
http://msdn.microsoft.com/en-us/library/ms164283(v=vs.90).aspx &
http://msdn.microsoft.com/en-us/library/ms171453(v=vs.100).aspx &
http://msdn.microsoft.com/en-us/library/ms171454(v=vs.100).aspx.
This works in both VS2012RC & VS2010sp1 although I had to close & re-open the solution in both for any file additions or deletions in the _Src project to propagate into the linked project(s).
I am creating projects for the various versions (generally milestone versions like 2006, 07, 10 & 13) which have the relevant references to their DLLs, and a separate project called "_Src", which has a reference to 2007 because it has the leanest feature set, for the actually source code that is used by all of the other projects when they build.
I don't want to build the _Src project. How do I stop that?:
- Right-click the solution Root node in the Solution Explorer,
- go to configuration properties -> Configuration.
- Change the configuration dropdown (top left on VS2012) to "All Configurations",
- then untick the build checkbox for the source project.
I am trying this in both VS2010sp1 & VS2012RC at the same time (different computers) and so far, so good. My real goal is to also share the _Src code with a stand-alone app using the ODA Teigha.NET (classic) library. Yeah, because my life is not already complicated enough.
There are various other things to watch for like target framework, x86/x64 (I got a build warning on v2007 for this but it usually doesn't matter AFAIK), changing method names (I'll use Tony's extension methods for this), a universale AssemblyInfo etc. I'll update as I crash into other things. As I said, it's a work in progress. Any input is most welcome.
cheers
Ewen
Update - this is the latest rendition of my XML to specify what is compiled in the project that references the source code:
<ItemGroup>
<!--This is where to include / exclude source code files-->
<Compile Include="..\_Src\**\*.*" Exclude="..\_Src\Properties\AssemblyInfo.cs;..\_Src\bin\**\*.*;..\_Src\obj\**\*.*;..\_Src\**\*.csproj;..\_Src\**\*.user;..\_Src\**\*.vstemplate;..\_Src\readme.txt;..\_Src\**\*.lsp;..\_Src\**\*.scr">
</Compile>
<Compile Include="Properties\AssemblyInfo.cs" />
</ItemGroup>
The source project has an AssemblyInfoForAllProjects.cs and each project has an AssemblyInfo.cs with just the AssemblyTitle, AssemblyDescription & COM GUID in it. The rest of the info, common to every project inthe solution, lives in AssemblyInfoForAllProjects.cs
