Author Topic: Help with error function  (Read 3855 times)
« on: February 23, 2005, 04:19:17 PM »
I decided to put some error checking (thanks CAB) in my routine but I'm getting this error every after i run the code. Could somebody take a look and see what I am doing wrong?
Command:
Error: too many arguments; error: An error has occurred inside the *error*
functiontoo many arguments
(defun c:drip (/ P u-plinegen u-clayer u-plinewid)         ;Used for inserting bubbler laterals
;_____________________________
;Error function
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
       (princ (strcat "\nError: " msg))
    ) ; if
(setvar 'plinegen u-plinegen)
(setvar 'clayer u-clayer)
(getvar 'plinewid u-plinewid)
  ) ;end error function
;Function to draw polyline
(defun drawpline (/)
  (command "_.pline")
  ;;   repeat a point input until Enter
  (if (while (> (getvar "CMDACTIVE") 0)
(command pause)
    (*error* "")
;Get User Variables
(setq u-plinegen (getvar 'plinegen)
u-clayer   (getvar 'clayer)
u-plinewid (getvar 'plinewid)
;Get User Variables
  (setvar 'plinegen 1)
  (initget 0 "Tree Shrub Bub Header Cv")      ;Gets T or S or B or H or C
  (if (not *defaultDRIP*)(setq *defaultDRIP* "Shrub"))
  (setq P (cond ((getkword (strcat "\nEnter an option (T)ree, (S)hrub, (B)ub, (H)eader, or (C)v Lateral  <<Hit Enter for " *defaultDRIP* ">>: ")))
  (*defaultDRIP*)))
  (if (not (eq P ""))(setq *defaultDRIP* P))
  (if (= P "Tree")
(if (tblsearch "layer" "0280-tree-lateral")
(command "-layer" "thaw" "0280-tree-lateral" "on" "0280-tree-lateral" "")
      (setvar 'plinewid (* (getvar "dimscale") 0.025))
      (command "_.-Layer"   "_Make"    "0280-tree-lateral"
          "_L"       "hidden2"    ""         "_Color"
          "4"       ""       ""
   (drawpline)
Jeff_M
  • C3D user & customizer
« Reply #1 on: February 23, 2005, 04:43:35 PM »
I think you want an "s" where you currently have a "g"....
« Reply #2 on: February 23, 2005, 05:00:46 PM »
You could see if these changes suit you too :
Declare the *error* function local ;
(defun c:drip (/ *error* p u-plinegen u-clayer u-plinewid)
revise the drawpline function to remove the (*error* "")
    (command "_.pline")
    (while (> (getvar "CMDACTIVE") 0) (command pause))
Revise your closing statement to call the *error* routine, passing nil , to clean up your variables.
  (*error* nil)
« Reply #3 on: February 23, 2005, 05:44:55 PM »
Good start, take Kerry's advice.
(defun c:drip (/ *error* p u-plinegen u-clayer u-plinewid) ;Used for inserting bubbler laterals
 ;Error function
      (not
        (member
          msg
    ) ; if
    (setvar 'plinewid u-plinewid)
  (defun drawpline ()
    (command "_.pline")
  (defun ck_layer (lyr ltype color)
     (if (tblsearch "layer" lyr)
       (command "._-Layer" "_Thaw" lyr "_On" lyr "_UnLock" lyr "_Set" lyr "")
       (command "_.-Layer" "_Make" lyr "_L" ltype "" "_Color" color "" "")
 ;Get User Variables
 ;Get User Variables
  (if (not *defaultdrip*)
    (setq *defaultdrip* "Shrub")
  (setq p (cond
            ((getkword
                       *defaultdrip*
            (*defaultdrip*)
  ;;  p will never be ""
  (setq *defaultdrip* p)
    ((= p "Tree")
     (ck_layer "0280-tree-lateral" "hidden2" "4")
     (drawpline)
    ((= p "Shrub")
    ((= p "Bulb")
    ((= p "Header")
    ((= p "Cv")
  ) ; end cond stmt
  (*error* "")
« Reply #4 on: February 23, 2005, 05:45:26 PM »
That was the ticket Jeff :)
Kerry, I'll take a look at your sugestions.
Thank you both.
Ron
« Reply #5 on: February 23, 2005, 07:27:46 PM »
Food for thought.
With a couple simple functions --
;;  retrieve all the values for the list
;;  of system variable names passed. No
;;  hand holding here, if you pass invalid
;;  varnames: rake handle in the face.
(defun getvars ( varNameList )
    (mapcar
       '(lambda (varName)
            (cons varName (getvar varName))
        varNameList
;;  attempt to set the system variable
;;  varName to varValue. Trap any errors
;;  like atempting to set clayer to a non
;;  existant layer. Return attempt to set
;;  as boolean value (not used in demo
;;  code below but could be).
(defun setvarp ( varName varValue )
    (null
        (vl-catch-all-error-p
            (vl-catch-all-apply
               '(lambda ()
                    (setvar
                        varName
                        varValue
;;  set the system variables according
;;  to the values in the list. Call our
;;  custom setvarp function to trap
;;  any pebkac errors.
(defun restore ( restoreList )
    (mapcar
       '(lambda (pair)
            (setvarp (car pair) (cdr pair))
        restoreList
    ;;  the following statement for
    ;;  demonstration purposes only
        (princ "\nRestored settings:\n\n")
        (princDottedList
            (getvars
                (mapcar 'car restoreList)
;;  just a perty printer for the demo
(defun princDottedList ( lst )
    (foreach pair lst
        (princ
            (strcat
                (car pair)
                (vl-princ-to-string (cdr pair))
                "\n"
A demo app (overly wordy logic for illustrative puposes) --
(defun c:MyDemoApp ( / *error* restoreList varList )
    ;;  have our error routine
    ;;  call our restore utility
    (defun *error* ( msg )
        (princ (strcat "\n<" msg ">\n"))
        (restore restoreList)
    ;;  save a list of the system variables
    ;;  we intend to muck about with
    (setq varList
            "cmdecho"
            "plinegen"
            "plinewid"
    ;;  save the system variable values
    (setq restoreList (getvars varList))
    ;;  show existing system variable values
    (princ "\nSettings prior to c:MyDemoApp execution:\n\n")
    (princDottedList restoreList)
    ;;  abuse our system variables
    (setvar "cmdecho"  (abs (1- (getvar "cmdecho"))))
    (setvar "plinegen" (abs (1- (getvar "plinegen"))))
    (setvar "plinewid" (* 100.0 (max 1 (getvar "plinewid"))))
    ;;  show new system variable values
    (princ "\nSettings used by c:MyDemoApp:\n\n")
    (princDottedList (getvars varList))
    ;;  now do something that might chuck a wobbly
    (getstring "\nPress <Enter> to continue, <Esc> to crash: ")
    ;;  if we made it here we didn't chuck a wobbly
    ;;  on the statement above; restore our saved
    ;;  settings explicity
    (princ "\n<Normal exit>\n")
    ;;  shhhh ...
Normal program termination --
MyDemoApp<Enter>
    cmdecho = 0
    plinegen = 1
    plinewid = 0.0
    cmdecho = 1
    plinegen = 0
    plinewid = 100.0
Press <Enter> to continue, <Esc> to crash: <Enter>
<Normal exit>
Restored settings:
    cmdecho = 0
    plinegen = 1
    plinewid = 0.0
Error termination --
MyDemoApp<Enter>
    cmdecho = 0
    plinegen = 1
    plinewid = 0.0
    cmdecho = 1
    plinegen = 0
    plinewid = 100.0
Press <Enter> to continue, <Esc> to crash: <Esc> *Cancel*
<Function cancelled>
Restored settings:
    cmdecho = 0
    plinegen = 1
    plinewid = 0.0
Foolproof? No, can't help a user who leans on the <Esc> key but it is better than nothing.
Cheers
« Reply #6 on: February 23, 2005, 07:45:33 PM »
Thanks MP...I'll try to absorb all this :)
Ron
« Reply #7 on: February 23, 2005, 08:04:52 PM »
hehehehe
Is 'chuck a wobbly' the same as 'spit the dummy' , sort of ... ?
