Author Topic: AutoLoader for MgdDbg  (Read 24458 times)
Jeff H
Re: AutoLoader for MgdDbg
« Reply #30 on: July 22, 2015, 12:16:12 AM »
Thank you for the update, huiz.
I had not done it because I am angry with AutoCAD 2016 as it will not have solved the problem with customized osnaps.
Revit 2016 came out after AutoCAD and they have released service pack 2 for revit 2016
BlackBox
« Reply #31 on: July 25, 2015, 06:14:04 PM »
I finally took the time to update this tool for 2014 and 2015 versions . I did not make an installer, just extract the folder "Autodesk DWG MgdDBG.bundle" in the directory plug-ins: "%appdata%\Autodesk\Plug-ins" (rename the previous folder if it was already installed).
I have not thoroughly tested or corrected all existing bugs in the original version. I only did the necessary changes to compile the DLLs with the libraries of each version from AutoCAD 2012 to 2015.
Thanks to the effort by gile, it was quite easy to rebuild this for 2016.
Here you can download the complete source and bundle data. I also did not create an installer, just save the bundle at the location described above.
FYI - I went to download this just now, and receive a 'service unavailable' message.
huiz
  • Certified Prof C3D
« Reply #32 on: July 26, 2015, 05:41:42 AM »
Hm, my OwnCloud installation hanged on an update. After the update it is completely corrupted.
Here is a new download link: https://drive.google.com/file/d/0B-yYJaopU61qTzFRM3FycHRfbjA/view?usp=sharing
BlackBox
« Reply #33 on: July 30, 2015, 04:48:32 PM »
No worries; I've only now even had a spare minute to revisit - Thanks for all of your help, my friend!
Cheers
