Thank you for the update, huiz.
I had not done it because I am angry with AutoCAD 2016 as it will not have solved the problem with customized osnaps.
Thank you too for the work you've done for the 2015 version. I only needed to define a new constant and add it to the #ifs.
Unfortunately the AutoCAD 2016 release is buggy, they also "repaired" features that were not broken. Like the Fatal error that occurs when loading a large amount of images, in the 2015 release that still worked. And the weird stuff, like the Start document that can't be closed but acts like a true document when you want the opened drawings tiled.
Well anyway we have to deal with it and keep hope for a better release next year
![smiley :-)](http://www.theswamp.org/Smileys/black/smiley.gif)
