Author Topic: AutoCAD .NET Addin Wizard (AcadNetAddinWizard)  (Read 22114 times)
MexicanCustard
« on: April 11, 2012, 09:47:20 AM »
Anybody using the wizard available here - http://spiderinnet1.typepad.com/?
Looks great but when I install the .msi its not showing up in VS2010 PRO.  Just wondering if anyone else is using it and if they did something special to get it to install.
sdunn
Re: AutoCAD .NET Addin Wizard (AcadNetAddinWizard)
« Reply #1 on: April 11, 2012, 10:12:55 AM »
I have installed it and it works on VS2010 express c#, but there are problems when running it from the vb version.
« Reply #2 on: April 11, 2012, 10:45:06 AM »
Do you have VS 2008 & 2010 installed?
Does it show up in 2008 if both installed?
MexicanCustard
« Reply #3 on: April 11, 2012, 10:53:14 AM »
I only have VS2010 installed.
« Reply #4 on: April 11, 2012, 11:46:21 AM »
Try this as it worked for me
-Right-Click on msi and click Unblock
-Run again and repair.
-Start Vs 2010
-Start new project
----Not sure about this one but did not notice it unit I changed Framework to 3.5 and back to 4.0
-Click on language(CSharp,VB,etc..) root node
« Reply #5 on: April 11, 2012, 11:57:05 AM »
Wow , someone put some effort into this.
BlackBox
« Reply #6 on: April 11, 2012, 01:40:43 PM »
I also use Express, but don't have rights to install without IT; could you elaborate?
I've been using the AutoCAD .NET Wizard that Kean recommended, and it's worked fine so far, so is there any advantage for this new(-er) one?
« Reply #7 on: April 11, 2012, 02:44:51 PM »
Have not gone through it but just glanced at it for a second, but has a ton a templates built and options to select for templates.
The code generated could be great, or it could just download porn for all I know but quickly glances at it and the amount of templates and options looked impressive.
To get a idea just look at the link posted by MC
Project Templates
http://spiderinnet1.typepad.com/blog/2012/03/using-acadnetaddinwizard-in-visual-basic-2008-express-to-create-autocad-net-addins.html
Some of the item templates
http://spiderinnet1.typepad.com/blog/2012/04/define-lisp-functions-in-vbnet-using-lispfunction-definer-of-acadnetaddinwizard.html
http://spiderinnet1.typepad.com/blog/2012/03/create-circle-jig-quickly-using-entity-jigger-of-autocad-net-addin-wizard-acadnetaddinwizard.html
BlackBox
« Reply #8 on: April 11, 2012, 04:38:22 PM »
While I did briefly skim the link in the OP, I had no idea that all of that documentation was available on the site... I thought clarification was needed regarding the installed files. Sorry to waste your time, Jeff. I appreciate the additional links.
Cheers!
mohnston
  • CAD Programmer
« Reply #9 on: April 11, 2012, 05:50:42 PM »
WOW indeed!
Very interesting.
CAD Programming Solutions
MexicanCustard
« Reply #10 on: April 13, 2012, 08:50:40 AM »
Thanks Jeff!. I just looked under the root folder for c# add it was there. I just dont have the folder for the add-in showing all the individual templates.
*EDIT*
Just used it to test it out and the startup is excellent. It gives alot of control over naming gives me options on which AutoCAD to use during debugging.  Creates a LISP routine to Autoload your app while debugging. Adds more references and usings.  So far, far and away better than the Autodesk version.
« Last Edit: April 13, 2012, 08:54:34 AM by MexicanCustard »
« Reply #11 on: April 13, 2012, 09:19:32 AM »
All the different templates are item templates which are templates like('class', 'interface') so you add them to a project so once you got a project created you can
right-click on project file --> Add --> New Item
Then select Autocad Addin
MexicanCustard
« Reply #12 on: April 13, 2012, 10:13:05 AM »
DOH! :ugly: Thanks Jeff! Works as intended now.
What a find! Autodesk should just post this on their SDK site and throw theirs away.
BlackBox
« Reply #13 on: April 22, 2012, 11:01:00 AM »
Silly question, I've unblocked and installed to default folder, but am still not able to see the add-in(s) in VS2010 (full). I've changed the framework, created foo projects for each 3.5 and 4.0, closed, reopened... nothing shows up.  :|
Have I overlooked something?
« Reply #14 on: August 17, 2012, 02:00:16 AM »
Does anyone know the identity of the writer/author/owner at http://spiderinnet1.typepad.com/blog/ ?
