Author Topic: vl-file-copy and vl-file-systime  (Read 2657 times)
fieldguy
  • Mosquito
« on: April 03, 2012, 07:54:49 PM »
I am using acad 2009 and vlisp to copy files from network to local folders. It works great except the copied files have todays date and time.  The end result will be used to update semi-dynamic files based on the network versions so comparing file dates and times is a requirement.  Is there a way to copy the file and maintain its original attributes?
TIA
BlackBox
Re: vl-file-copy and vl-file-systime
« Reply #1 on: April 04, 2012, 01:41:40 AM »
Some other options include:
Xcopy with /k
FileSystemObject CopyFile() Method
System.IO.File.Copy() ... Which is really Kernel32.dll's CopyFile
That last one would require a .NET LispFunction Method.
irneb
« Reply #2 on: April 04, 2012, 02:21:14 AM »
Good point,
The xcopy can be run through a startapp call (though it might open a command console window). The FileSystem can the run through  (vlax-get-or-create-object "Scripting.FileSystemObject").
If you go the DotNet route with the System.IO namespace, you might even be able to modify the creation/modification dates after the fact.
alanjt
  • Standby for witty remark...
Dropbox
BlackBox
« Reply #5 on: April 04, 2012, 11:55:46 AM »
Good point,
Thanks.
To paraphrase "The Most Interesting Man in the World:" I do not use batch files that often, but when I do, I prefer to display the console.
Pseudo code:
@echo off
title Your title goes here
if exist Z:\ goto :yes
goto :no
:yes
echo/
echo/
echo Working, please wait...
xcopy "source\*.*" "destination" /d /e /h /k /q /r /y
cls
color 2f
echo/
echo/
echo Working, please wait... Done
echo/
echo/
pause
goto :end
:no
color 4f
echo/
echo/
echo No worky, fix something and try again.
echo/
echo/
pause
:end
I've been meaning to put together a small library of LispFunction Methods for the System.IO.File Class, maybe I'll do that here shortly.
« Last Edit: April 04, 2012, 12:19:38 PM by RenderMan »
