Thanks for the link Tony.
A bit over 2 years since the original posting ... Is the issue actually closed/resolved ... can't make the time to read fully at the moment.
It's closed, but as a result they did make some changes in .NET 4.0 (they now support both the generic and non-generic ICollection at every point where they previously supported only ICollection<T>), and that was a direct result of that feedback, but I have been lobbying for more, along the lines of my prototype.
The summary of the proposal is that, with the changes I outlined implemented, the number of items that will be returned by a complex LINQ expression like what follows can be determined
without having to execute the expression and iterate over the returned items (as is required today):
ICollection items = // assigned to non-generic ICollection
var expr = items.Cast<TSomething>().Select( a => a.b ).OrderBy( b => b.c );
// here, the count is obtained without executing the LINQ expression:
int count = expr.Count();
The scheme involves adding an interface to the objects returned by
Select(), OrderBy(), Cast() (and others), that would allow each of
them to query their adjacent operator/source argument for a count.
Because each of those iterator objects returned by the LINQ operators
shown in the example are often the source of another iterator object,
the query can propagate down the calling chain until one of the objects
in it returns a count, that would then be returned back up the chain of
callers until it reaches the Count() method call and becomes its result,
and we've deduced the number of items in the result of the composite
LINQ expression
without executing it.
Today, as the design exists in all current versions of the framework, the
call to Count() in the above example triggers execution of the LINQ
expression, to produce a resulting count, and the expressions result is
unreachable, requiring the expression be executed again, in order to
make use of it.
The optimizations are not only for the sake of the Count() method.
They're also beneficial to ToArray(), ToList(), ToDictionary(), ToLookup(),
and so forth, because they must incrementally grow an array in order
to build their result when the count of items is unknown. If the count
of items is known, they can allocate the needed array capacity in one
swell foop (similar to how the
List<T>(int capacity) constructor works).
So in the above example, the Count() method would ask the object
returned by OrderBy() for a count. The object returned by OrderBy()
would in-turn ask the object returned by Select() for a count, which
in-turn asks the object returned by Cast() for a count. The object
returned by Cast() would examine its source argument; see that it is
an ICollection (that knows how many elements it contains), and simply
return the value if it's ICollection.Count property.
The caveat (of course there's always one or two), is that this scheme
only works with LINQ operators that return a determinant number of
items. LINQ operators whose result count is indeterminate and depend
on conditional branching (an example of which is the Where() operator)
cannot implement the interface or participate in the scheme, since they
can't determine how many items they will yield without actually executing
and producing the result.
