Author Topic: Asking for a lisp to insert blocks relates to list.  (Read 2451 times)
HasanCAD
« on: February 06, 2012, 07:33:13 AM »
Hi all
Could some one help me with this lisp?
I want to insert block with attribute related to a list
blocks   already inserted in file
Re: Asking for a lisp to insert blocks relates to list.
« Reply #1 on: February 06, 2012, 08:35:27 AM »
Need more information.  :-)
HasanCAD
« Reply #2 on: February 06, 2012, 09:26:51 AM »
Thanks CAB for quick reply
These blocks with attribute are in a file
A
B
C
D
I want to insert them in a column or a row with specified distance depending on a list
A A C D A A D D D .....
HasanCAD
« Reply #3 on: February 06, 2012, 10:17:53 AM »
Lets tell all the story
We are structural consultant one of our jobs is creating a Bar Binding List Which has all bars with its data
We draft the bars on the plan then export ATTOUT to modify some data the ATTIN again as a table
The next step is adding a symbol in the table depending on the SHAPE CODE
My planing was to pick the cell then pick SHAPE CODE
the lisp should read the contents of the shape code contents then insert the block then read the next cell contents ( A ) to add in the block attribute then next cell then next cell
I hope that I explained the idea
Attached a part of a file with BBL
« Reply #4 on: February 06, 2012, 03:50:37 PM »
It's been a long time ago that I did anything with tables.
Why don't you update the shape code before the data is imported / created?
A simple lisp could be used to add the shape to PREVIEW that matched the shape code.
Just a suggestion. Obviously I don't know all the processes at work here.
HasanCAD
« Reply #5 on: February 07, 2012, 01:31:10 AM »
That what I am planing for. But the preview should be has the values
For Example see attached
HasanCAD
« Reply #6 on: February 07, 2012, 01:42:37 AM »
These are blocks
there are 2 types one to use in plan and another one to use in table
« Reply #7 on: February 07, 2012, 08:02:43 AM »
This is where I would start:
http://www.theswamp.org/index.php?topic=13878.msg167603#msg167603
The zip file contains the routines.
Just enter the block names in the PREVIEW cells before you bring the table into ACAD.
This section of code will update the block cells.
  1. ; This function converts a column of data cell with a blocknames into
  2. ; A column of block cells with symbols
  3.
  4. (defun AU06:ConvertBlockNameToSymbol (objTable       ; Object Table
  5.                                       intNumColumn   ; Integer Column Index
  6.                                       /
  7.                                       intNumRow      ; Integer Row Index
  8.                                       intObjectID    ; Integer Block Definition Object ID
  9.                                       strBlockName)  ; String Block Name
  10.  (repeat (- (setq intNumRow (vla-get-rows objTable)) 2)
  11.   (setq intNumRow   (1- intNumRow ))
  12.   (and
  13.    (AU06:Errortrap (quote (setq strBlockName (vla-getText objTable intNumRow intNumColumn))))
  14.    (AU06:Errortrap (quote (setq intObjectID (vla-get-objectID
  15.                                              (vla-item
  16.                                               (vla-get-blocks
  17.                                                (vla-get-activedocument
  18.                                                 (vlax-get-acad-object)))
  19.                                               strBlockName)))))
  20.    (AU06:Errortrap
  21.     (quote (vla-setcelltype objTable intNumRow intNumColumn acBlockCell)))
  22.    (AU06:Errortrap
  23.     (quote (vla-setblocktablerecordID objTable intNumRow intNumColumn intObjectID :vlax-true)))
  24.    (AU06:Errortrap
  25.     (quote (vla-SetCellAlignment objTable intNumRow intNumColumn acMiddleCenter))))))
HasanCAD
« Reply #8 on: February 12, 2012, 01:25:29 AM »
Thanks CAB
