I am about to write a lisp that will check if there any update lisps to run and run them
For example
- add some new lisp the the appload startup suite
- check something for me and write it to a log file
I am currently thinking of having a folder \lisps\updates with files update001.lsp update002.lsp. The program will read from the registry which update lisp is current, look for it, if it is present run it, log whether it worked or not, then change the registry value to look for the next routine.
Any other ideas, on a similar way to implement this. Does anyone have anything similar already written?
Regards Rod
