Author Topic: distiguish variable between a number or a word  (Read 2547 times)
andrew_nao
« on: January 05, 2012, 03:13:13 PM »
hello all and happy new year.
my first request for the new year  :-o
can anyone help me with how i can get code to tell the difference between a variable being words or numbers?
example
(if var = a word
 (do this)
(if var = a number
(do this)
any help is appreciated
alanjt
  • Standby for witty remark...
Re: distiguish variable between a number or a word
« Reply #1 on: January 05, 2012, 03:40:17 PM »
You could check with the type function - if I'm understanding correctly.
Command: (type 3.4)
REAL
Command: (type 3)
INT
Command: (type "3.4")
STR
Dropbox
andrew_nao
« Reply #2 on: January 05, 2012, 04:05:40 PM »
thanks for the reply Alan, however my variables will always be in quotes so it will come up as a string and not an integer
alanjt
« Reply #3 on: January 05, 2012, 04:08:31 PM »
Try distof...
Command: (distof "3.4")
3.4
Command: (distof "blah")
nil
Dropbox
andrew_nao
« Reply #4 on: January 05, 2012, 04:11:45 PM »
thanks again but that isnt working either
my number is returned as a string and looks like this
"97 01000 000 16 99 10"
and distof returns nil
alanjt
« Reply #5 on: January 05, 2012, 04:14:52 PM »
Give me a few examples to go on - as word and as number.
Dropbox
andrew_nao
« Reply #6 on: January 05, 2012, 04:26:16 PM »
 a word, for instance, would be
"plate" or "pipe".   just a plain word.
and a number would be
the number would be exactly like you see it here but with different digits
same spacing format.
both would be returned via my existing code as strings
Jeff_M
  • C3D user & customizer
« Reply #7 on: January 05, 2012, 04:48:23 PM »
A fairly simplistic solution for this specific case:
(if (wcmatch str "*@*")
  (princ "\nIt is a string.")
  (princ "\nIt is a number")
fixo
« Reply #8 on: January 05, 2012, 04:51:06 PM »
just for the single words without digits (not for "cloud number 9" etc):
(vl-some '(lambda(x)
(or (distof (chr x))(eq 32 x)))
(vl-string->List StringExpression))
(alert "number")
(alert "word"))
« Reply #9 on: January 05, 2012, 04:51:50 PM »
Nice  8-)
alanjt
« Reply #10 on: January 05, 2012, 06:48:39 PM »
There you go. :-)
Nice  8-)
Dropbox
andrew_nao
« Reply #11 on: January 09, 2012, 10:44:35 AM »
thanks everyone
both solutions work perfectly
didnt think it was that easy... :ugly:
