Author Topic: count up  (Read 1424 times)
Hugo
count up
« on: January 05, 2012, 10:10:27 AM »
Hello
Can I change a the Lisp so it works well with less.
Will not tolerate it.
Thank you
100.1/10
100.1/9
100.1/09
Hallo
Kann mir einer das Lisp so ändern das es auch mit minus funktioniert.
Bekomme das nicht hin.
Danke
;; INCSUFF -Gilles Chanteau- 2008/01/15
;; Adds the specified increment to a string suffix.
;; Is considered as suffix, all [0-9], [A-Z] and [a-z] characters from
;; the end of the string according to flag value.
;; Arguments
;; str : a string
;; inc : a positive integer
;; flag : an integer, the sum of following binary codes
;;       1 for numbers [0-9]
;;       2 for uppercase  [A-Z]
;;       4 for lowercase [a-z]
;; Return
;; The string with incremented suffix (or nil if none valid suffix)
;; Examples :
;; (incsuff "N° 002" 12 1) = "N° 014"
;; (incsuff "Drawing_A" 1 1) = "Drawing_B"
;; (incsuff "test_ZZ9" 1 3) = "test_AAA0"
;; (incsuff "test_ZZ9" 1 1) = "test_ZZ10"
;; (incsuff "12-" 1 nil) = nil
;; Update (13/02/08) : binary codes
(defun incsuff (str inc flag / lst crt pas ind dep quo ret)
  (setq lst (reverse (vl-string->list str)))
  (while
    (and
      (setq crt (car lst))
((< 47 crt 58)
(setq pas 10
       ind 48
((and flag (< 64 crt 91))
(setq pas 26
       ind 65
((and flag (< 96 crt 123))
(setq pas 26
       ind 97
((< 0 quo)
(setq crt (if (= 10 pas)
     ind
     (1- ind)
       lst (cons (car lst) lst)
     (setq dep (- crt ind)
   quo (/ (+ dep inc) pas)
   ret (cons (+ ind (rem (+ dep inc) pas)) ret)
     (if (zerop quo)
       (setq ret (append (reverse (cdr lst)) ret)
     lst nil
       (if (cdr lst)
(setq lst (cdr lst)
       inc quo
(setq lst (list ind)
       inc (if (= 10 pas)
     quo
     (1- quo)
  (if ret
    (vl-list->string ret)
Re: count up
« Reply #1 on: January 05, 2012, 06:07:52 PM »
Show the before and after of what you want for a result.
Hugo
Re: count up
« Reply #2 on: January 06, 2012, 04:47:55 AM »
Hello
before   "100.1/10"
after     "100.1/9   and "100.1/09"
before  "100.1/02"
after     "100.1/01"
before "100.1/2"
after   " 100.1/1"
Danke
Re: count up
« Reply #3 on: January 06, 2012, 09:06:08 AM »
Oh, you want to subtract the suffix.
Like this
(incsuff "100.1/02" -1 1)
"100.1/01"
I see it doesn't work in all cases.
(incsuff "100.1/10" -1 1)
"100.1/1/"
Re: count up
« Reply #4 on: January 06, 2012, 09:29:56 AM »
The routine would need to be reworked to handle negative values
but this is a start:
 replace this
        ((< 47 crt 58) ; numbers
           (setq pas 10
                 ind 48
with this:
         (if (minusp inc)
           (setq pas 10
                 ind 57
           (setq pas 10
                 ind 48
This is not a complete solution.
Hugo
Re: count up
« Reply #5 on: January 06, 2012, 10:16:22 AM »
@CAB
Thank you
This is the best forum  :-) :-) :-)
Danke
Das ist das beste Forum
« Last Edit: January 06, 2012, 11:54:00 AM by Hugo »
