Author Topic: why text is very blurry ?  (Read 8859 times)
MUQTAR
« on: December 26, 2011, 04:17:46 PM »
Some time my text is become blurry looks like a bold why this problem
when i check my text properties all are ok like text width and text rotation
Re: why text is very blurry ?
« Reply #1 on: December 26, 2011, 05:59:50 PM »
Text that does not lie in the XY plane with zero elevation is sometimes not rendered smoothly, this occurs with Tables also.
MUQTAR
« Reply #2 on: December 27, 2011, 02:14:35 AM »
Thansk Forreply
can you give me the solution
« Reply #3 on: December 27, 2011, 03:01:50 AM »
Can you post (attach)  a drawing containing your very blurry text please ??
Preferably a drawing containing some clear and some blurry text
MUQTAR
« Reply #4 on: December 27, 2011, 05:48:13 AM »
Look at the image there is same height of text and font's
« Last Edit: December 27, 2011, 05:55:03 AM by MUQTAR »
Jeff H
« Reply #5 on: December 27, 2011, 07:33:35 AM »
Are you sure it is not the lineweights for objects, scale, etc.... or whatever.
Try toggling on or off Lineweights or Enter LWDISPLAY at commandline and set to 'OFF' to see if that makes them appear on screen the same, if so then need to make change for printing.
« Reply #6 on: December 27, 2011, 07:34:07 AM »
FYI: Since AutoCAD graphics are vector based, saving a screenshot in a lossless compression format (such as .png / .gif) will result in a clearer image over lossy compressions (such as .jpg).
« Reply #7 on: December 27, 2011, 08:05:09 AM »
... or better yet ...
MUQTAR
« Reply #8 on: December 27, 2011, 08:25:15 AM »
No,
i check my "LWDISPLAY' IT'S OFF
I m attaching my dwg. here you can try this
thanking for helpful reply's,
Tharwat
  • Hypersensitive
« Reply #9 on: December 27, 2011, 08:35:59 AM »
Hi
All that because of the Z coordinates , so flatten the texts and things would be OK.  ;-)
fixo
« Reply #10 on: December 27, 2011, 05:32:57 PM »
Thansk Forreply
Hint
Set in your drawings system variable ELEVATION to 0.0
if you're working in the plain drawings
« Reply #11 on: December 27, 2011, 06:00:16 PM »
This piccy may illustrate about the different elevations.
Notice the relative locations of the selected text.
MUQTAR
« Reply #12 on: December 28, 2011, 05:13:39 AM »
" FLATTEN " command its work,
thank you   :-) Mr. Tharwat
And thanks for everyone for valuable comments.
« Last Edit: December 28, 2011, 05:16:42 AM by MUQTAR »
Tharwat
  • Hypersensitive
« Reply #13 on: December 28, 2011, 08:30:10 AM »
You're welcome  :-)
