Author Topic: AutoCAD Cannot close  (Read 8789 times)
Big G
« on: February 15, 2005, 07:42:28 AM »
AutoCAD Cannot close - there is a command still active
NO THERE IS NOT!!!
 :evil: Grrrrrrr!
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
« Reply #1 on: February 15, 2005, 07:50:28 AM »
Make sure all other dwgs are closed.
Big G
« Reply #2 on: February 15, 2005, 07:52:30 AM »
wondering if the two problems are now related mark!
Quote from: Mark Thomas
yep they are...only 1 drg open.
Is today a monday???
David Hall
  • Automatic Duh Generator
« Reply #3 on: February 15, 2005, 08:21:55 AM »
Do you have a VBA command that you crashed out of?  I get this when I lose my link to excel, and Autocad wont close.
« Reply #4 on: February 15, 2005, 08:39:32 AM »
hit escape about a dozen times and then try to close ... I have had the same problem ....
« Reply #5 on: February 15, 2005, 08:47:08 AM »
I have a 22 oz. Eastwing that will take care of that problem every time. :twisted:
Big G
« Reply #6 on: February 15, 2005, 09:00:36 AM »
Quote from: CAB
hmmm interesting.
If you type exit at the command line it will let me close out of it then, but esc does nothing.
jwisherd
« Reply #7 on: February 24, 2005, 10:35:06 AM »
If your drawing is saved, you can ctrl/alt/del and kill the autocadd process.
CADaver
« Reply #8 on: February 24, 2005, 10:51:42 AM »
REFEDIT still open??
Big G
« Reply #9 on: February 24, 2005, 11:29:34 AM »
Quote from: jwisherd
Nope seems to crash out of a command..though none in particular seems to be the cause
Quote from: CADaver
Am working with a large xref, but not using refedit CADaver.
daron
« Reply #10 on: February 24, 2005, 11:34:43 AM »
You could always saveas a different name, close, delete the offending dwg and rename the new one.
CADaver
« Reply #11 on: February 24, 2005, 12:20:03 PM »
Quote from: Big G
hmmm... enough space for the BAK file on the drive??
Big G
« Reply #12 on: February 25, 2005, 04:47:43 AM »
Yes 10gig or so.
Have blamed it on the network and am now getting a 1Gb network conx. maybe this will sort the problem out!!
doubt it but at least it will be a faster problem :lol:
CADaver
« Reply #13 on: February 25, 2005, 10:28:24 AM »
Quote from: Big G
Yes 10gig or so.
Cool faster failure, I like it.
Did someone make the directory "Read Only"??
ScottMC
Re: AutoCAD Cannot close
« Reply #14 on: May 11, 2021, 02:49:45 PM »
So far, haven't found the problem/why but using [ _.qsave  close ] < +made a short on top, has saved me many a time!!
