Author Topic: I BEG of You!!! Think before you Explode...  (Read 4308 times)
craigr
« on: December 09, 2011, 08:32:26 AM »
PLEASE don't use a sand Hatch - Then explode it!!!
Espacially if it is on a layer with MANY other items!!
It is horribly difficult to clean every little grain of sand from that dwg.
If any of you have a tip how to do it, I would be THRILLED to hear it.
This person used it on the same layer as the walls, and the only option I see is to go thru the entire dwg and click on the LINES of the walls and change them to a different layer. Then delete that Sand layer, hoping that the Sand is the only thing on that layer.
I SO WISH that Autodesk never created that layer!!! - I HATE it!!!
Or at a minimum, make it so that you cannot explode it.
craigr
« Last Edit: January 26, 2012, 04:32:18 PM by CAB »
Rob...
Re: I BEG of You!!!
« Reply #1 on: December 09, 2011, 08:36:31 AM »
Use QSELECT to pick all lines with a length of "0" and erase. Done.
CAD Tech
Re: I BEG of You!!!
« Reply #2 on: December 09, 2011, 08:38:21 AM »
This code will delete all zero length lines (to a tolerance of 1e-8), in a selection:
(defun c:dzl ( / e i l s ) ;; Delete Zero-Length Lines
    (if (setq s (ssget "_:L" '((0 . "LINE"))))
        (repeat (setq i (sslength s))
            (setq e (ssname s (setq i (1- i)))
                  l (entget e)
            (if (equal (cdr (assoc 10 l)) (cdr (assoc 11 l)) 1e-8)
                (entdel e)
Matt__W
  • I like my water diluted.
Re: I BEG of You!!!
« Reply #3 on: December 09, 2011, 08:39:22 AM »
Remember... he's using LT.
Autodesk Expert Elite
Crank
Re: I BEG of You!!!
« Reply #4 on: December 10, 2011, 07:01:09 AM »
In acad2012 you can use:
-purge z
CaddmannQ
Re: I BEG of You!!!
« Reply #5 on: December 10, 2011, 03:56:30 PM »
Does LT not have the quick select filter?
I just select everything & filter by lines with length = 0.
Re: I BEG of You!!!
« Reply #6 on: December 11, 2011, 08:03:33 AM »
Oops! Hopefully the code will be useful to others viewing the thread  :-)
craigr
Re: I BEG of You!!!
« Reply #7 on: January 19, 2012, 02:02:35 PM »
Sorry folks, I just found out that I forgot to post my 'Thanks' for the suggestions.
QSelect lines les that zero worked great.
BTW, I chewed out our guy that used then exploded that Hatch. - He kinda laughed at me and said he figured that I wouldn't like it.a
Go figure.
alanjt
  • Standby for witty remark...
Re: I BEG of You!!!
« Reply #8 on: January 19, 2012, 02:04:37 PM »
And you're not running from the law for the actions that followed his comment?!?!
Dropbox
diarmuid
Re: I BEG of You!!!
« Reply #9 on: January 23, 2012, 04:52:03 AM »
we had a guy like that, here.  he was an ISP (Contractor)  I got so fed up that i banned him from accessing the server.  This caused quite a commotion i tell you.  As all of the other ISP's were in a bit of a fret.  "This is the way we always worked" they'd say.  No it wasnt would be the reply, you were just let get on with it running rough shod over the CAD standards.  My argument (which was upheld by senior magement) was if we got a contractor to come into our buidling and install or do some remidial works we would want him to do it to a particular standard  (ie the building regualtions at least)  if he did not do that, then he either repaired the work or he wasnt paid.  And he wasn't paid anymore money if he needed to repair it.  So, in far as reasonalby practical, adhereance to the CAD standards they are all behaving themselves now.  Any deviation from the CAD standards needs to be preagreed and resonable justifaction must be provided prior to any deviation.
If you want to win something run the 100m, if you want to experience something run a marathon
Nibster
Re: I BEG of You!!!
« Reply #10 on: January 23, 2012, 09:12:01 AM »
... do it to a particular standard  (ie the building regualtions at least)  if he did not do that, then he either repaired the work or he wasnt paid. ..
i love this analogy.
alanjt
Re: I BEG of You!!!
« Reply #11 on: January 26, 2012, 04:23:36 PM »
Just noticed this in 2011\2012:
Command: -pu
-PURGE
Enter type of unused objects to purge
[Blocks/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTylesMlinestyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]:
Dropbox
Crank
Re: I BEG of You!!!
« Reply #12 on: February 01, 2012, 01:51:16 PM »
Command: -pu
-PURGE
I told you so.
alanjt
Re: I BEG of You!!!
« Reply #13 on: February 01, 2012, 02:01:25 PM »
Command: -pu
-PURGE
I told you so.
Oops. Sorry about that.
Dropbox
M-dub
Re: I BEG of You!!! Think before you Explode...
« Reply #14 on: February 02, 2012, 11:09:58 AM »
-purge z
 :kewl:
