Author Topic: how to permute the y by the z values of a point  (Read 3898 times)
DEVITG
« on: February 14, 2005, 03:26:24 PM »
Hi all .
I have this points whos Y values shall be permuted  with the Z Values , so all the Y becomes Z and the Z becomes Y .
It is like to rotate the all poinst  90 degree by the x axis.
This point are the coordenates of 12 radii spaced 7.5 degree on a half circle.
(setq k1(200.0 0.0 0.0)
(setq k2(199.144 13.0526 0.0)
(setq k3(196.593 25.8819 0.0)
(setq k4(192.388 38.2683 0.0)
(setq k5(186.603 50.0 0.0)
(setq k6(179.335 60.8761 0.0)
(setq k7(170.711 70.7107 0.0)
(setq k8(160.876 79.3353 0.0)
(setq k9(150.0 86.6025 0.0)
(setq k10(138.268 92.388 0.0)
(setq k11(125.882 96.5926 0.0)
(setq k12(113.053 99.1445 0.0)
(setq k13(100.0 100.0 0.0)
The result shall be
(setq k1(200.0 0 0)
(setq k2(199.144 0 13.0526)
(setq k3(196.593 0 25.8819)
(setq k4(192.388 0 38.2683)
(setq k5(186.603 0 50)
(setq k6(179.335 0 60.8761)
(setq k7(170.711 0 70.7107)
(setq k8(160.876 0 79.3353)
(setq k9(150.0 0 86.6025)
(setq k10(138.268 0 92.388)
(setq k11(125.882 0 96.5926)
(setq k12(113.053 0 99.1445)
(setq k13(100.0 0 100)
I see about the Trans function , but I can not understand it.
Thanks in advance.
« Reply #1 on: February 14, 2005, 04:26:00 PM »
Here's a simple approach....
(defun permute_yz (pt / )
  (list (car pt) (caddr pt) (cadr pt))
whdjr
« Reply #2 on: February 14, 2005, 04:59:25 PM »
Simplicity is normally the best approach.
MP (not logged in)
« Reply #3 on: February 14, 2005, 05:21:12 PM »
Just for fun --
(defun SwapCoords ( point fx fy fz)
    (list
        (fx point)
        (fy point)
        (fz point)
(SwapCoords '(1 2 3) car caddr cadr)
=> (1 3 2)
« Reply #4 on: February 14, 2005, 05:37:49 PM »
HA?! Awesome!
Heres mine. (BTW, Jeff, you stole my idea ...again?! :P I had to think of a diff way to do this for a second. *lol*)
(defun swap_yz (lst)
  (if (not (eq (length lst) 3))
    lst
    (cons (car lst) (reverse (cdr lst)))))
« Reply #5 on: February 14, 2005, 06:12:17 PM »
Is nth too slow?
(defun SwapCoords ( point xn yn zn)
    (list
        (nth xn point)
        (nth yn point)
        (nth zn point)
(print (SwapCoords '(11 22 33) 0 2 1)) ; new order, 0 based
« Reply #6 on: February 14, 2005, 07:06:14 PM »
Quote from: CAB
Is nth too slow?
    (list
        (nth fx point)
        (nth fy point)
        (nth fz point)
Neglible performance hit. Probably more intuitive to use nth values (as opposed to car et al), but I would rename the arguments to something more appropriate, like xn yn zn.
« Reply #7 on: February 14, 2005, 07:21:52 PM »
Thank you Sir,
Your wish is my command.
Not really, it just sounds cool. 8)
DEVITG
sweping values
« Reply #8 on: February 14, 2005, 08:45:21 PM »
Hi all , tahnks for it , I will try it .
BTW , how to do it to all the point?
Tanks in advance
« Reply #9 on: February 14, 2005, 09:04:22 PM »
Personally I don't see the need for all those individual variables (k1 thru kn), but then again, I don't have the benefit of knowing the context of how the data will be used.
Anyway, if I had a hard list of point values this is how I might do it --
(setq points
        (200.0 0.0 0.0)
        (186.603 50.0 0.0)
        (150.0 86.6025 0.0)
        (100.0 100.0 0.0)
(setq pointsXZY
    (mapcar
       '(lambda (point)
            (list
                (car point)
                (caddr point)
                (cadr point)
        points
