Author Topic: Having heavier lines and symbols show on DWG To PDF plots  (Read 3664 times)
cannorth
« on: November 09, 2011, 02:32:30 PM »
Hello,
  Whenever we create a PDF from a drawing using DWG to PDF, the lines are lighter and some of the symbols are lighter or don't show.  How can this be corrected to show darker lines and symbols like with a standard Adobe PDF plot from AutoCAD?
Thanks,
cannorth
M-dub
Re: Having heavier lines and symbols show on DWG To PDF plots
« Reply #1 on: November 09, 2011, 02:43:59 PM »
Are you plotting with a CTB file, using Object Lineweights?
If so, maybe they just need to be bumped up.
Krushert
  • FREE BEER Tomorrow!!
« Reply #2 on: November 09, 2011, 02:53:26 PM »
Create a adobe PC3 plotter config file if you haven't already.  Thru Autocad plot window, check your DPI settings.  They may need bump up.
cannorth
« Reply #3 on: November 09, 2011, 03:31:20 PM »
Hello,
   We're using a CTB file.  We'd like to avoid bumping about the DPI because it'll make the PDF file larger.
Thanks,
cannorth
M-dub
« Reply #4 on: November 09, 2011, 03:35:15 PM »
Hello,
Thanks,
cannorth
How about the lineweights, though?
cannorth
« Reply #5 on: November 09, 2011, 03:52:10 PM »
Lineweights don't seem to make a difference.
cannorth
Krushert
« Reply #6 on: November 09, 2011, 03:59:07 PM »
Hello,
Thanks,
cannorth
okay.  What version of Autocad are you using?
Also have you tried printing the pdf to a different printer to verify it is not the printer?
M-dub
« Reply #7 on: November 09, 2011, 04:00:09 PM »
As a test, change the lineweights of one of the colours that you're using in the drawing to something like 1.00 or something rather heavy and try it.
Also, I didn't ask... when you print these on paper, are you getting the desired result?
cannorth
« Reply #8 on: November 09, 2011, 04:15:19 PM »
Changing the lineweight of all the colors worked.  We are getting the desired result from the drawing as well.
Thanks,
cannorth
cannorth
« Reply #9 on: November 09, 2011, 04:46:10 PM »
Hello,
   The lineweights are darker now, but we've discovered that circle symbols aren't as crisply drawn in DWG to PDF as they are in Adobe PDF.
Thanks,
cannorth
M-dub
« Reply #10 on: November 09, 2011, 05:19:37 PM »
Hello,
Thanks,
cannorth
Try setting your VIEWRES up to 10000 or more before you print to pdf.
dgorsman
« Reply #11 on: November 09, 2011, 06:11:30 PM »
Might want to re-check the PDF paper size being created.  I've had users complain about this type of problem, turns out they were "printing" A1/ANSI D drawings to PDF at 11x17, then printing back at full size.  PDFs plot down-size well but up-size, not so much.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
