Author Topic: Obsolete warnings ... various  (Read 13928 times)
Gasty
Re: Obsolete warnings ... various
« Reply #15 on: November 04, 2011, 06:28:14 PM »
As for the VS confusing db tables and acad tables, that can be avoided using an alias, like:
using fTable = Autodesk.AutoCAD.DatabaseServices.Table
-gnb
« Reply #16 on: November 04, 2011, 06:37:02 PM »
Welcome to theSwamp Gasty.
Yes, using an alias works fine locally ... though I've had no issue with the compiler understanding the Class.
My issue is with 'google' and desktop searches for the word 'Table'.
... probably just a personal problem :)
« Reply #17 on: November 04, 2011, 10:29:17 PM »
IMHO, some warnings are just to keep the newbie's out of trouble.
For Tables,  I see no issue with setting the number of rows and columns when creating a table, it's the subsequent calls  that can cause problems.  A safer and more generic way to "add" rows & columns would be.
tb.InsertRows( tb.Rows.Count, rowHeight, numRows - tb.Rows.Count);
tb.InsertColumns(tb.Columns.Count, colWidth, numCols - tb.Columns.Count);
in fact, this might make a good extension method. (Add)
I do like the newer style, its more dataset like
« Reply #18 on: November 04, 2011, 10:31:29 PM »
yes,   and I like it too.
mohnston
  • CAD Programmer
« Reply #19 on: November 07, 2011, 12:53:32 PM »
-gnb
Welcome indeed!
I hadn't thought of that. Thank you.
BTW - This is only an issue if you are "using" both Autodesk.AutoCAD.DatabaseServices and System.Data in the same class.
CAD Programming Solutions
