Author Topic: foreach x lst to mapcar cdr lst  (Read 4610 times)
jaydee
« on: October 22, 2011, 09:22:13 AM »
Hi.
Please show me how to do this
Lst1 '("aa" "bb" "cc" "n")
lst2  '(("1" . "V1")("2" . "V2")("3" . "V3")("4" . "V4"))
(("1" . "aa")("2" . "bb")("3" . "cc")("4" . "n"))
thankyou
Re: foreach x lst to mapcar cdr lst
« Reply #1 on: October 22, 2011, 09:26:55 AM »
Maybe;
(mapcar '(lambda ( a b ) (cons (car a) b)) lst2 lst1)
jaydee
« Reply #2 on: October 22, 2011, 10:01:58 AM »
Thankyou Lee
This is perfect.
I had tried a few combinations and some are very close to yours.
One thing im keep thinking is the (cdr (assoc  of the lst2.
Your one liner give me great insight of trying to understand the code.
« Reply #3 on: October 22, 2011, 11:33:25 AM »
You're welcome jaydee  :-)
If you have any questions about the methods or code, just ask.
jaydee
« Reply #4 on: October 22, 2011, 12:39:29 PM »
Now i got another issue convert mtext paragraph string with enter return on each line
("Abc\\pefg\\pPPP")
("abc" "efg" "PPP")
thanks
« Reply #5 on: October 22, 2011, 01:18:59 PM »
Perhaps take a look at this  :-)
« Reply #6 on: October 22, 2011, 04:54:19 PM »
Maybe this:
;  parser by CAB multi char delim, match "xyz"
(defun sparser (str delim / dlen ptr lst)
  (setq dlen (1+ (strlen delim)))
  (while (setq ptr (vl-string-search delim str))
    (setq lst (cons (substr str 1 ptr) lst))
    (setq str (substr str (+ ptr dlen)))
  (reverse(cons str lst))
(sparser "Abc\\pefg\\pPPP" "\\p")
("Abc" "efg" "PPP")
« Reply #7 on: October 22, 2011, 04:57:27 PM »
Oh, sorry Lee I should have looked at the link. We have the same answer. :oops:
jaydee
« Reply #8 on: October 22, 2011, 07:20:19 PM »
Thankyou Cab and Lee
Another perfect answers.
« Reply #9 on: October 22, 2011, 07:35:47 PM »
No worries Alan, the more the merrier  8-)
jaydee
« Reply #10 on: October 22, 2011, 08:52:44 PM »
Hi Lee and Cab
How to get around a string that looks like this
DBA\P1
AAA
BBB
CCC
(setq lst '("DBA\\\\P1\\PAAA\\PBBB\\PCCC"))
(sparser lst "\\P")
("DBA\\" "1" "AAA" "BBB" "CCC")
(LM:str->lst lst "\\P")
prefer result
("DBA\P1" "AAA" "BBB" "CCC")
Thankyou
« Last Edit: October 22, 2011, 11:17:11 PM by jaydee »
jaydee
« Reply #11 on: October 23, 2011, 04:59:39 AM »
Refer to my previous post.
Just relise its a sticky issue.
The stripmtext3.5 could not do it.
Xpress tool text2mtext could not do it.
My way of getting around the "\P" in the string is do a find and replace \P to /P before using the program.
Thankyou
« Reply #12 on: October 23, 2011, 07:45:07 AM »
This is almost the correct result except the double \\ should be a single \
You would need to replace \\ with \ to finish the job.
(sparser lst "\\P")
« Reply #13 on: October 23, 2011, 07:47:26 AM »
Unformat String can do it  8-)
_$ (LM:Unformat "DBA\\\\P1\\PAAA\\PBBB\\PCCC" nil)
"DBA\\P1 AAA BBB CCC"
« Reply #14 on: October 23, 2011, 07:50:42 AM »
Maybe I missed something but I thought this is correct for removing \\P
The first group in plain text should be DBA\
