Author Topic: if statement to fix error  (Read 1956 times)
butzers09silverado
« on: October 20, 2011, 01:40:21 PM »
it appears that when the layer is already set to "0" in the drawing we get an invalid layer error... thoughts?
(or *vla-AcadObject* (setq *vla-AcadObject* (vlax-get-acad-object)))
(or *vla-ActiveDocument* (setq *vla-ActiveDocument* (vla-get-ActiveDocument *vla-AcadObject*)))
(or *vla-LayersCollection* (setq *vla-LayersCollection* (vla-get-Layers *vla-ActiveDocument*)))
;; Adjust the layer 0
(if (not (vl-catch-all-error-p (setq l (vl-catch-all-apply 'vla-Item (list *vla-LayersCollection* "0")))))
    (vla-put-LayerOn l :vlax-true)
    (vla-put-Freeze l :vlax-false)
    (vla-put-Lock l :vlax-false)
(setvar 'CLayer "0")
kojacek
  • Mosquito
Re: if statement to fix error
« Reply #1 on: October 20, 2011, 01:47:38 PM »
You can not freeze current layer.
best regards
kojacek
« Reply #2 on: October 20, 2011, 02:19:44 PM »
Maybe move around the catch-all:
(if (setq l (tblobjname "layer" "0"))
  (progn (setq l (vlax-ename->vla-object l))
(vl-catch-all-apply 'vla-put-freeze (list l :vlax-false))
(vl-catch-all-apply 'vla-put-lock (list l :vlax-false))
(vl-catch-all-apply 'vla-put-layeron (list l :vlax-true))
(setvar 'clayer "0")
butzers09silverado
« Reply #3 on: October 24, 2011, 04:36:46 PM »
what kind of slow down do you figure this is causing?
« Reply #4 on: October 24, 2011, 05:30:38 PM »
Ummmm ... not sure what you are referring to  :?
