Author Topic: Is there a versatile way sorting multi format string with chracters and numbers  (Read 2611 times)
jaydee
Hi.
Just wondering is there a vesatile way or function that could sort multi-formatted string with numbers, or do i have to write one for each format.
These are the string extracted from block attributes and the order i would them to appear, these are equipment labels and format is specify by the client.
("PC 5.01" "PC 5.02" "PC 5.10" "PC 6.01" "PC 6.11")
("PDU-NT5/2" "PDU-NT5/3" "PDU-NT6/1" "PDU-NT6/2" "PDU-NT6/11")
("ASTS NT5-01" "ASTS NT5-02" "ASTS NT5-11" "ASTS NT6-01" "ASTS NT6-11")
("TF-NT5-1" "TF-NT5-2" "TF-NT5-11" "TF-NT6-1" "TF-NT6-2" "TF-NT8-1")
("MDB-ST5/01" "MDB-ST5/02" "MDB-ST5/11" "MDB-ST5/21" "MDB-ST6/01" "MDB-ST6/11")
Thankyou
pBe
Hi.
Thankyou
I can think of a few ways to approach this, you need to set an identifier for every format i.e. "." "/" "-" "/ and -" , also a flag for " 0" prefix all in one function
look into vl-sort function
This is the function written by gile used in my TabSort program to perform the 'Architectural Sort', I believe it will perform as required:
(defun _ArchSort ( lst / comparable ) ; (Gile)
    (defun comparable ( e1 e2 )
        (or
            (and (numberp e1) (numberp e2))
            (= 'STR (type e1) (type e2))
            (not e1)
            (not e2)
    (mapcar '(lambda ( x ) (nth x lst))
        (vl-sort-i (mapcar '_SplitStr lst)
            (function
                (lambda ( x1 x2 / n1 n2 comp )
                    (while
                            (setq comp
                                (comparable (setq n1 (car x1)) (setq n2 (car x2)))
                            (= n1 n2)
                            (setq x1 (cdr x1))
                            (setq x2 (cdr x2))
                    (if comp (< n1 n2) (numberp n1))
(defun _SplitStr ( str / lst test rslt num tmp ) ; (Gile)
    (setq lst  (vl-string->list str)
          test (chr (car lst))
    (if (< 47 (car lst) 58)
        (setq num T)
    (while (setq lst (cdr lst))
        (if num
                (   (= 46 (car lst))
                            (cadr lst)
                            (setq tmp (strcat "0." (chr (cadr lst))))
                            (numberp (read tmp))
                        (setq rslt (cons (read test) rslt)
                              test tmp
                              lst  (cdr lst)
                              test "."
                              num nil
                (   (< 47 (car lst) 58)
                    (setq test (strcat test (chr (car lst))))
                (   t
                          num  nil
                (setq rslt (cons test rslt)
                      num  T
    (if num
        (setq rslt (cons (read test) rslt))
        (setq rslt (cons test rslt))
    (reverse rslt)
_$ (_ArchSort '("PC 6.11" "PC 5.02" "PC 5.01" "PC 6.01" "PC 5.10"))
_$
_$
_$ (_ArchSort '("PDU-NT6/2" "PDU-NT5/2" "PDU-NT6/11" "PDU-NT6/1" "PDU-NT5/3"))
_$
_$
_$ (_ArchSort '("ASTS NT6-01" "ASTS NT5-11" "ASTS NT5-02" "ASTS NT6-11" "ASTS NT5-01"))
_$
_$
_$ (_ArchSort '("TF-NT6-1" "TF-NT5-2" "TF-NT5-1" "TF-NT6-2" "TF-NT8-1" "TF-NT5-11"))
_$
_$
_$ (_ArchSort '("MDB-ST6/11" "MDB-ST5/21" "MDB-ST5/02" "MDB-ST5/11" "MDB-ST5/01" "MDB-ST6/01"))
« Last Edit: October 19, 2011, 08:02:49 AM by Lee Mac »
Not as well written as Gile's but my old sort.  8-)
http://www.theswamp.org/index.php?topic=6474.0
jaydee
Thankyou Lee, Cab, pBe.
This is exactly what i want.
jaydee
Hi Lee and cab
Just would like to mention this little issue with _ArchSort where it fails if there is duplication in the list. I understand where the code intent to re-order layout tabs where its not possible to duplication tab names. But for me i use it for checking equipment used in layouts.
ie. this will fall over on acad 2006
(_ArchSort '("PC 5.01" "PC 5.01" "PC 6.11" "PC 5.02" "PC 6.01" "PC 5.10"))
where as Cabs code run successfully
(num_Sort '("PC 5.01" "PC 5.01" "PC 6.11" "PC 5.02" "PC 6.01" "PC 5.10"))
("PC 5.01" "PC 5.01" "PC 5.02" "PC 5.10" "PC 6.01" "PC 6.11")
Thanks again Cab and Lee. Its a a very good piece of code
VVA
My 5 cent
(SortStringWithNumberAsNumber '("PC 5.01" "PC 5.01" "PC 6.11" "PC 5.02" "PC 6.01" "PC 5.10") t)
===> ("PC 5.01" "PC 5.01" "PC 5.02" "PC 5.10" "PC 6.01" "PC 6.11")
Search of Windows type Sort function
Thanks for reporting that  :-)
I have updated the above code.
jaydee
Hi.
Also one more question i would like to ask. Thankyou in advance, I wish i could figure it out myself.
The code below will append "-" if the next integer number are greater then last more then 1 (gap between integer numbers)
(defun NumberCheck (lst / result diff)
 (setq result (list (car lst))
       lst    (cdr lst)
 (while (car lst)
  (if (> (- (atoi (substr (car lst) 2))
    (atoi (substr (last result) 2))
1
   (setq result (append result (list "-" (car lst))))
   (setq result (append result (list (car lst))))
 result
(NumberCheck '("P1" "P3" "P4" "P5" "P17" "P18" "P19" "P23" "P24" "P25"))
("P1" "-" "P3" "P4" "P5" "-" "P17" "P18" "P19" "-" "P23" "P24" "P25")
But for these multi-formated such as these list below, how could i append "-" in between string if the next label in greater then 1
ie.
("ASTS NT5-01" "ASTS NT5-02" "ASTS NT5-11" "ASTS NT5-12" "ASTS NT6-11")
("ASTS NT5-01" "ASTS NT5-02" "-" "ASTS NT5-11" "ASTS NT5-12" "-" "ASTS NT6-11")
« Last Edit: October 19, 2011, 08:20:16 AM by jaydee »
jaydee
Thankyou VVA, that seems to be another verygood sorting function.
Thankyou Lee for the update.
jaydee
Hi.
Please assist with argument in function. Im struggling getting this to work.
How to provide (car lst) and (last result) in the function below as an argument, if I run ( get#fromMixedStr "PC-1.01XY") will return value
Thankyou. Been playing this code all night with lots of trial/error thingy. I finally figure it out, it was the list not being localised, therefore the list just keep building up.
101
;;extract number from selected text
;;By Andrea Andreetti
;;12/05/2001
(defun addnum ()
(if (= num nil)
 (setq num "")
(setq num (strcat num ftxt))
(defun get#fromMixedStr (lst1 / len1 val ftxt)
;;;(setq mixedstr "PC-1.01XY")
(setq len1 (strlen lst1))
(setq val 1)
(repeat len1
  (setq ftxt (substr lst1 val 1))
   (if (= ftxt ".")
    (setq ftxt "")
   (if (numberp (read ftxt))
    (addnum)
   (setq val (+ val 1))
   num
The result i would like
(setq lst '("PDU-NT5/2" "PDU-NT5/3" "PDU-NT6/1" "PDU-NT6/2" "PDU-NT6/11"))
(setq lst '("PDU-NT5/2" "PDU-NT5/3" "-" "PDU-NT6/1" "PDU-NT6/2" "-" "PDU-NT6/11"))
therefor i think my problem is the argument in the function
(get#fromMixedStr (car lst))
(get#fromMixedStr (last result))
(defun NumberCheck2 (lst / result diff)
          lst (cdr lst)
 (while (car lst)
   (> (- (atoi (get#fromMixedStr (car lst)))
       (atoi (get#fromMixedStr (last result))))
     1
 result
« Last Edit: October 20, 2011, 09:16:12 AM by jaydee »
