Author Topic: CTB or STB  (Read 11788 times)
M-dub
Re: CTB or STB
« Reply #15 on: October 04, 2011, 10:51:51 AM »
ctb.
because they work.
I have not seen a compelling reason to switch to stb.
Yep... Pretty much.
cadtag
Re: CTB or STB
« Reply #16 on: October 04, 2011, 01:00:05 PM »
Chris, if you have access to Autodesk University, David Garrigues' class Civil 3DŽ Caffeinated Tips and Tricks: A Yard Sale, Tip #9 has some good arguments for using STB, and explains how to implement them. We still use CTB's, even though I've been pushing for STB for a few years.
Informative, however, it still doesnt address what to do if you are using Dimensions/Multileaders, in which the lines are different shading than the text.
If your Dimension Text uses a TTF font instead of an SHX, the the color/weight assigned to the text will have no affect on the plotted appearance of the text.  The TTF outline definition will over-ride.
Chris
Re: CTB or STB
« Reply #17 on: October 04, 2011, 01:04:04 PM »
unless you are applying a shaded value to the text (60%)  I'm working on getting a bold font so we dont need to use shaded text to make some text stand out.
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
