Author Topic: Yet another error from autocad....  (Read 3560 times)
AVCAD
« on: February 09, 2005, 04:21:32 PM »
What is and how do I get rid of.....
**undefined shape ##
ya it sux.... :?
Architects......uhhhhhh...
« Reply #1 on: February 09, 2005, 04:40:15 PM »
That error is typically from a font file that is missing or a font that has been changed in the drawing. If a font references a specific item in a shx file (the number of the undefined shape) and it is not available of "defined" in the font file, the error is generated.
diarmuid
« Reply #2 on: February 11, 2005, 03:45:05 AM »
could that problem also be caused by a custom linetype definition file that has not been created properly?
we have that problem a lot and its only now i've realised that our acadiso.lin is loading but it is reporting errors.
any feedback would be greatly appreciated.
Regards
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
Big G
« Reply #3 on: February 11, 2005, 04:38:01 AM »
try getting the arch to 'pack' the drawing and re-send it to you, this will include and shape files or custom LT definitions
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
diarmuid
« Reply #4 on: February 11, 2005, 06:18:12 AM »
Good stuff
i'll give it a bash
AVCAD
« Reply #5 on: February 11, 2005, 09:49:24 AM »
anyway of purging this from the files?
Big G
« Reply #6 on: February 11, 2005, 10:08:47 AM »
unless you find the offending linetype or shape and delete all the instances of it in the drawing and re-save/purge?
MikePerry
« Reply #7 on: February 11, 2005, 10:17:50 AM »
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS19683 - Erase shapes and purge references to unavailable shape (SHX) files
Have a good one, Mike
<edit CAB: repaired link>
« Last Edit: September 11, 2011, 11:10:54 AM by CAB »
