Author Topic: Why select by window part of a block and the block get selected  (Read 5246 times)
irneb
Re: Why select by window part of a block and the block get selected
« Reply #15 on: September 29, 2011, 12:14:51 PM »
Now that's interesting. Do you know what this "reference counter" is so I can set it to 0 somewhere? Actually reading that lot, it seems to be a variable inside the acet_SSGet function which gets turned on if the :n switch is used. So it only affects programatically selecting nested entities.
jaydee
« Reply #16 on: September 29, 2011, 09:51:32 PM »
Thankyou all.
It could save me some explaining if i could utilise these video captures.
1 picture = 10000 words.
May i ask what video/screen captures software do you guys used or recommend???.
Jeff H
« Reply #17 on: September 29, 2011, 10:06:28 PM »
If you have windows 7 then you can use snipping tool
irneb
« Reply #18 on: September 30, 2011, 01:01:14 AM »
For mine I used CamStudio to make an AVI, then opened that in VirtualDub and exported to GIF. Then used A Smaller GIF to make it about 30% of the original size. The 1st 2 are free, the last costs very little.
You could also go with something like Camtasia Studio which can do all those steps in one, though it costs a bit. I did it on XP so didn't have snip available, didn't know it did video capture, will have to investigate!
« Reply #19 on: September 30, 2011, 07:49:06 AM »
http://www.theswamp.org/index.php?topic=38447.0
