Author Topic: ...not declared. It may be inaccessible due to its protection level.  (Read 21186 times)
Matt__W
  • I like my water diluted.
I'm trying to format an Excel spreadsheet using VB.NET and I'm getting a lot of warnings regarding the Excel formatting code (this worked in VBA).
oExcel.Selection.Borders(xlDiagonalDown).LineStyle = xlNone
I've imported Excel (Imports Microsoft.Office.Interop.Excel) and all other functions of my app work except for the parts where it needs to format the cells.  Any thoughts?
Autodesk Expert Elite
Jeff H
Re: ...not declared. It may be inaccessible due to its protection level.
« Reply #1 on: September 21, 2011, 05:29:43 PM »
This worked for me using a windows form application
Public Class Form1
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim exl As New Microsoft.Office.Interop.Excel.Application()
        Dim wb As Microsoft.Office.Interop.Excel.Workbook = exl.Workbooks.Open("C:\Test\ExcelTest.xlsx")
        Dim ws As Microsoft.Office.Interop.Excel.Worksheet = TryCast(exl.ActiveSheet, Microsoft.Office.Interop.Excel.Worksheet)
        exl.Visible = True
        Dim rang As Range = ws.Cells(1, 1)
       rang.Borders.Weight = Microsoft.Office.Interop.Excel.XlBorderWeight.xlThick
        rang.Borders(Microsoft.Office.Interop.Excel.XlBordersIndex.xlEdgeBottom).LineStyle = Microsoft.Office.Interop.Excel.XlLineStyle.xlDashDotDot
        '''''wb.Close(True, Type.Missing, Type.Missing)
        ''''exl.Quit()
End Class
« Last Edit: September 21, 2011, 05:34:16 PM by Jeff H »
Matt__W
« Reply #2 on: September 22, 2011, 08:14:16 AM »
Ahhh.... okay.  I think I see where it's throwing a wobbly.  Thanks!
David Hall
  • Automatic Duh Generator
« Reply #3 on: October 28, 2011, 02:18:33 PM »
I cant seem to make this work
this is what I have done
try
                xlApp.Visible = true;
                xlApp.UserControl = true;
                Excel.Range currentFind = null;
                Excel.Range firstFind = null;
                currentFind = (Excel.Range)ws.Columns["B",Type.Missing ];
                firstFind = currentFind.Find(strDwgNum, Type.Missing, Excel.XlFindLookIn.xlValues, Excel.XlLookAt.xlWhole, Excel.XlSearchOrder.xlByRows, Excel.XlSearchDirection.xlNext, 0, 0, Type.Missing);
                string foundAddress = firstFind.get_Address(Type.Missing, Type.Missing, Excel.XlReferenceStyle.xlA1, Type.Missing, Type.Missing);
                firstFind.Activate();
                int rowNum = firstFind.Row;
                Excel.Range rowRange = (Excel.Range)ws.Cells("A",rowNum);
                rowRange.Value2 = strDwgRev;
Jeff H
« Reply #4 on: October 28, 2011, 02:48:49 PM »
        [CommandMethod("OpenExcelEarlyBind")]
        public void OpenExcelEarlyBind()
            Microsoft.Office.Interop.Excel.Application exl = new Microsoft.Office.Interop.Excel.Application();
            Microsoft.Office.Interop.Excel.Workbook wb = exl.Workbooks.Open(@"C:\Test\ExcelTest.xlsx");
            Microsoft.Office.Interop.Excel.Worksheet ws = exl.ActiveSheet as Microsoft.Office.Interop.Excel.Worksheet;
            ws.Range["A1"].Value = "Whatever";
            ws.Cells[2, 2] = "YoMama";
            exl.Visible = true;
David Hall
« Reply #5 on: October 28, 2011, 03:11:39 PM »
Thanks Jeff, Its always something simple!  I was trying too hard.
David Hall
« Reply #6 on: October 28, 2011, 05:29:10 PM »
Jeff, I got everything working, but Im trying to make a GetOrCreate method.  Have you ever done that?
David Hall
« Reply #7 on: October 28, 2011, 05:29:57 PM »
I'm trying to use this
static object GetInstance(string appName)
            return Marshal.GetActiveObject(appName);
        static object CreateInstance(string appName)
            return Activator.CreateInstance(Type.GetTypeFromProgID(appName));
        static object GetOrCreateInstance(string appName)
            try { return GetInstance(appName); }
            catch { return CreateInstance(appName); }
Jeff H
« Reply #8 on: October 28, 2011, 05:50:13 PM »
Tried it here and have done it the past, but kaefer seems to knows the 'gotchas' when using reflection.
        [CommandMethod("OpenExcelLateBind")]
        public void OpenExcelLateBind()
            Type excelType = Type.GetTypeFromProgID("Excel.Application");
            object exl = Activator.CreateInstance(excelType);
            object wb = exl.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, null, exl, null);
            object[] param = new object[1];
            param[0] = @"C:\Test\ExcelTest.xlsx";
            wb.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, null, wb, param);
            param = new Object[1];
            param[0] = true;
            exl.GetType().InvokeMember("Visible", BindingFlags.SetProperty, null, exl, param);
David Hall
« Reply #9 on: October 28, 2011, 06:18:36 PM »
Thanks for the reply Jeff.  Isn't that a Late bind example?  I was trying to early bind and grab Excel if its open, or open a new instance if it wasn't
exmachina
exmachina
« Reply #11 on: October 28, 2011, 07:43:24 PM »
Off topic:
COM events can also be used with late-binding, look at (System.Runtime...)IConnectionPointCointainer
Jeff H
« Reply #12 on: October 28, 2011, 07:58:50 PM »
Hey Bill,
Are you trying something like this?
            ExcelApp.Application exl;
            try
                exl = (ExcelApp.Application)Marshal.GetActiveObject("Excel.Application");
            catch
            if (exl.Workbooks[exl.Workbooks.Count].Name != "ExcelTest.xlsx")
            ExcelApp.Worksheet ws = exl.ActiveSheet as Microsoft.Office.Interop.Excel.Worksheet;
            exl.Visible = true;
            ws.Range["A1"].Value = DateTime.Now.ToLongTimeString();
            Marshal.FinalReleaseComObject(exl);
Thanks for info exmachina
David Hall
« Reply #13 on: October 31, 2011, 02:33:41 PM »
Hey Bill,
I am assuming you mean me.
            try
            catch
            exl.Visible = true;
Thats exactly what I was trying to do, thanks
David
Jeff H
« Reply #14 on: October 31, 2011, 02:45:08 PM »
da hell did I get Bill from?
Sorry David must have saw something with the name Bill right befor I posted it,
 glad it helped
