Author Topic: Prompt for User Input | Left, Right Arrow?  (Read 6376 times)
BlackBox
« on: August 10, 2011, 03:39:18 PM »
Does LISP (Auto, or Visual) support the ability to read user input from keyboard arrowentry? (left arrow, right arrow, specifically?)
If not LISP, how about C#/VB.NET?
I've been unable to find anything useful after several Google searches.  :|
alanjt
  • Standby for witty remark...
Re: Prompt for User Input | Left, Right Arrow?
« Reply #1 on: August 10, 2011, 03:48:50 PM »
I've mimicked it, but never found a way to read it.
Dropbox
BlackBox
« Reply #2 on: August 10, 2011, 04:02:52 PM »
Thanks for sharing!
It's interesting that you should respond, as I posed this question after initially thinking of incorporating the use of arrows into the 'Layout Navigation' thread over at CT. LoL
The only other way I've found to get around using the SendKeys Method (for something unrelated), was the use of NirCmd.exe
alanjt
« Reply #3 on: August 10, 2011, 04:05:04 PM »
Dropbox
alanjt
« Reply #4 on: August 10, 2011, 04:07:12 PM »
Nevermind, just read your link.
Dropbox
BlackBox
« Reply #5 on: August 10, 2011, 04:22:09 PM »
alanjt
Dropbox
Jeff H
« Reply #7 on: August 10, 2011, 05:32:27 PM »
You can try this
Add this to one of your practice files
You will need to add
using System.Windows.Interop;
And you might need to reference Windows.Base
Just run CaptureKeys command
         const int WM_CHAR = 258;
        [CommandMethod("CaptureKeys")]
        public void CaptureKeys()
            Application.PreTranslateMessage +=
              new PreTranslateMessageEventHandler(KeyHandler);
        [CommandMethod("StopCaptureKeys")]
        public void StopCaptureKeys()
            Application.PreTranslateMessage -=
        void KeyHandler(object sender, PreTranslateMessageEventArgs e)
            if (e.Message.message == WM_CHAR &&
                (e.Message.wParam.ToInt32() >= 0 &&
                e.Message.wParam.ToInt32() <= 190))
                e.Handled = true;
                char[] charr = { (char)80, (char)69, (char)78, (char)73, (char)83 };
                     string s = new string(charr);
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n" + s);
BlackBox
« Reply #8 on: August 10, 2011, 06:22:50 PM »
That's pretty neat, Jeff... can't wait to get my geek on and try implementing it.
Just 'cause I'm lazy right now... after skimming the C# code, I noticed that the 'capture' is passed to the Editor... how do I pass this to a LISP function as an argument instead of printing to the command line?
If you're feeling lazy too, no sweat, I'll look it up when I'm not feeling so lethargic. LoL
Jeff H
« Reply #9 on: August 10, 2011, 06:40:35 PM »
You can try this
                e.Handled = true;
Do not use that it was joking around and just prints a word to the command line
This one
When press a arrow key after calling CaptureKeys it will print "Up Arrow", "Left Arrow" etc......
Since e.Handled is true it stops AutoCad from recieving it.
  const int WM_KEYDOWN = 256;
            Editor ed = doc.Editor;
            if (e.Message.message == WM_KEYDOWN &&
                (e.Message.wParam.ToInt32() >= 37 &&
                e.Message.wParam.ToInt32() <= 40))
                e.Handled = true;
                switch (e.Message.wParam.ToInt32())
                    case 37:
                        ed.WriteMessage("\nLeft Arrow");
                        break;
                    case 38:
                        ed.WriteMessage("\nUp Arrow");
                        break;
                    case 39:
                        ed.WriteMessage("\nRight Arrow");
                        break;
                    case 40:
                        ed.WriteMessage("\nDown Arrow");
                        break;
                    default:
                        break;
Jeff H
« Reply #10 on: August 10, 2011, 06:57:45 PM »
Forgot you are a VB guy
and add
Imports System.Windows.Interop
 Const WM_KEYDOWN As Integer = 256
        <CommandMethod("CaptureKeys")> _
        Public Sub CaptureKeys()
            AddHandler Application.PreTranslateMessage, New PreTranslateMessageEventHandler(AddressOf KeyHandler)
        End Sub
        <CommandMethod("StopCaptureKeys")> _
        Public Sub StopCaptureKeys()
            RemoveHandler Application.PreTranslateMessage, New PreTranslateMessageEventHandler(AddressOf KeyHandler)
        End Sub
        Private Sub KeyHandler(sender As Object, e As PreTranslateMessageEventArgs)
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            If e.Message.message = WM_KEYDOWN AndAlso (e.Message.wParam.ToInt32() >= 37 AndAlso e.Message.wParam.ToInt32() <= 40) Then
                e.Handled = True
                Select Case e.Message.wParam.ToInt32()
                    Case 37
                        ed.WriteMessage(vbLf & "Left Arrow")
                        Exit Select
                    Case 38
                        ed.WriteMessage(vbLf & "Up Arrow")
                        Exit Select
                    Case 39
                        ed.WriteMessage(vbLf & "Right Arrow")
                        Exit Select
                    Case 40
                        ed.WriteMessage(vbLf & "Down Arrow")
                        Exit Select
                    Case Else
                        Exit Select
                End Select
            End If
        End Sub
BlackBox
« Reply #11 on: August 10, 2011, 06:59:10 PM »
My what a TINY 'word' you have, I must have overlooked it.  :-D LoL
This one
I'll have to take a look tomorrow sometime.
Cheers! :beer:
« Reply #12 on: August 11, 2011, 08:42:00 AM »
This my be overkill but not sure you could get it to work with LISP.
http://sourceforge.net/apps/mediawiki/pyhook/index.php?title=PyHook_Tutorial
BlackBox
« Reply #13 on: August 11, 2011, 12:10:08 PM »
It's definitely over my head, CAB... but I appreciate your sharing.
