Author Topic: Select all TEXT smaller than ...  (Read 1593 times)
Hangman
« on: July 21, 2011, 03:31:11 PM »
I am trying to select all the text in a drawing 1/8" or smaller and I've come across a blank spot in my head.
(setq A (ssget "_X" (list (cons (0 "Text")
                                (40 **???**)
I know this should be a simple thing, but I'm at a mental loss.
What do you suggest?
Thanks.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
Jeff_M
  • C3D user & customizer
Re: Select all TEXT smaller than ...
« Reply #1 on: July 21, 2011, 03:42:03 PM »
It's been a while, but I think this is what you are looking for.
(ssget "_X" '((0 . "Text")
                     (-4 . "<=")
                     (40 . 0.125)
Hangman
« Reply #2 on: July 21, 2011, 04:39:01 PM »
                     (-4 . "<=")
                     (40 . 0.125)
I was thinking I needed the [  (list (cons  ] because I was using two or more codes when I posted my question.
Then after posting my question, I got to think'n, ... 'I don't think there is a conditional operator for DXF' ... .
I'd of never thought of using the [  (-4 . "<=")  ] in this manner.  Glad you were here Jeff.
So I just learned something new today.  This works perfectly.  Thank you Jeff.
Hangman  8)
Tharwat
  • Hypersensitive
« Reply #3 on: July 21, 2011, 05:02:39 PM »
Hi .
This is a little bit long than the use of dxf operator but it is a good practice of looping to get (filter) what you in need of .
    (setq s (ssget "_x" '((0 . "TEXT"))))
       (repeat (setq j (sslength s))
         (setq e (ssname s (setq j (1- j))))
         (if (<= (cdr (assoc 40 (entget e))) 0.125)
           (ssdel e s)
       (sssetfirst nil s)
Tharwat
« Reply #4 on: July 21, 2011, 05:58:49 PM »
Hangman,
In the Visual LISP IDE Help Documentation, have a read of the following sections:
+ Using the AutoLISP Language
+--+ Using AutoLISP to Manipulate AutoCAD Objects
   +--+ Selection Set Handling
      +--+ Selection Set Filter Lists
         +--> Relational Tests
         +--> Logical Grouping of Filter Tests
