This was fun to write:
(defun c:tcase2 ( / acsel func name ) ;; © Lee Mac 2011
(ssget "_:L"
(-4 . "<OR")
(0 . "ARCALIGNEDTEXT,ATTDEF,*TEXT")
(-4 . "<AND")
(0 . "INSERT")
(66 . 1)
(-4 . "AND>")
(-4 . "<AND")
(0 . "*DIMENSION")
(1 . "*?*")
(-4 . "AND>")
(-4 . "<AND")
(0 . "MULTILEADER")
(304 . "~LEADER_LINE{")
(-4 . "AND>")
(-4 . "OR>")
(initget "Sentence Lower Upper Title toGgle")
(setq func
(eval
(cdr
(assoc
(setq case
(getkword
(strcat "\nSpecify Case [Sentence/Lower/Upper/Title/toGgle] <"
(setq case (cond ( case ) ( "Upper" ))) ">: "
( case )
("Upper" . strcase)
("Lower" . (lambda ( x ) (strcase x t)))
("Title" . EE:TitleCase)
("Sentence" . LM:SentenceCase)
("toGgle" . LM:ToggleCase)
(vlax-for obj
(setq acsel
(vla-get-activeselectionset
( (wcmatch (setq name (vla-get-objectname obj)) "AcDb*Dimension")
(vla-put-textoverride obj (func (vla-get-textoverride obj)))
( (or (eq "RText" name)(eq "AcDbArcAlignedText" name))
(vlax-put-property obj 'contents (func (vlax-get-property obj 'contents)))
( (eq "AcDbMLeader" name)
(if (eq acmtextcontent (vla-get-contenttype obj))
(vla-put-textstring obj (func (vla-get-textstring obj)))
( (eq "AcDbBlockReference" name)
(foreach att (vlax-invoke obj 'getattributes)
(vla-put-textstring att (func (vla-get-textstring att)))
( t
(vla-delete acsel)
(defun EE:TitleCase ( s ) ;; ElpanovEvgeniy
(vl-list->string
(mapcar
(function
(lambda ( a b c ) (if (= 32 a) b c))
(cons 32 (vl-string->list s))
(vl-string->list (strcase s))
(vl-string->list (strcase s t))
(defun LM:SentenceCase ( s / f )
(vl-list->string
(mapcar
(function
(lambda ( a b c )
(if (or f (= 46 a)) (progn (setq f (= 32 b)) b) c)
(cons 46 (vl-string->list s))
(defun LM:ToggleCase ( s )
(vl-list->string
(mapcar
(function
(lambda ( a b c ) (if (< 96 a 123) b c))
(vl-string->list s)
(vl-load-com) (princ)
Note that it won't work with formatted MText however.
