This is a dead-head (lacking the ability to think) question, but how is the SELECT command used, ... other than typing the whole word out?
Lemme 'splain,
While you are drawing away, if you type in SELECT and hit enter, it prompts you to 'select objects:'.
You hit the P key to get previous and hit enter and you have the previous selection, cool.
Now, if you type in (command "select" "P"), you get the previous selection set, but you are still in the command 'select objects: '. So if you hit the ENTER key, it takes you back to the command prompt, and you lose your previous selection set.
A really quick way to get nowhere is to type in (command "select" "P" "").
I came across this when I was trying to simplify typing out SELECT <enter> P <enter>.
What is the simplest way of getting a previous selection set?
