Author Topic: Move selected attribute by distance  (Read 2669 times)
Pad
« on: June 14, 2011, 09:35:51 AM »
Hello
I have been trying to modify this terrific lisp by Vovka so that the selected attribute is moved by a set distance.
The reason is to 'stack' the attributes when some of the other block attribute values are missing.
I wish to move the selected attributes -0.442 in the Y axis.
this is the lisp:
; Vovka http://www.theswamp.org/index.php?topic=21303.0
(defun C:MOVEATTXT (/ CE OS Ent EntProps LastPoint LastEnt *error*)
  (defun *error* (msg)
    (if OS
      (setvar 'OSMODE OS)
    (if CE
      (setvar 'CMDECHO CE)
    (if LastEnt
      (entdel LastEnt)
    (vl-cmdf "._UNDO" "_END")
    (if (or (= msg "Function cancelled") (= msg "quit / exit abort"))
      (princ (strcat "\nError: " msg))
  (setq OS (getvar 'OSMODE)
CE (getvar 'CMDECHO)
  (vl-cmdf "._UNDO" "_BEGIN")
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
    (and
      (progn (while (not (and (setq Ent (nentsel "\nSelect an attribute/text: "))
      (= (length Ent) 2)
      (wcmatch (cdr (assoc 0 (setq EntProps (entget (car Ent)))))
       "ATTRIB,TEXT"
     Ent
      (= (cdr (assoc 0 EntProps)) "ATTRIB")
      (setq LastPoint (cadr Ent)
    LastEnt   (entmakex
(cons
  (cons 0 "TEXT")
  (subst
    (cons 73 (cdr (assoc 74 EntProps)))
    (assoc 74 EntProps)
    (subst
      (cons
10
(cdr
  (assoc
      (= 0 (cdr (assoc 72 EntProps)) (cdr (assoc 74 EntProps)))
       10
       11
    EntProps
      (assoc 10 EntProps)
      (vl-remove-if
(function (lambda (g)
    (vl-position (car g) '(-1 0 2 5 70 73 100 280 330))
EntProps
       (setvar "LASTPOINT" LastPoint)
       (command "._MOVE" LastEnt "" (cadr Ent) PAUSE)
       (if (not (equal LastPoint (getvar "LASTPOINT")))
(progn (entmod
  (subst (assoc 11 (entget LastEnt))
(assoc 11 EntProps)
(subst (assoc 10 (entget LastEnt)) (assoc 10 EntProps) EntProps)
(entupd (car Ent))
       (entdel LastEnt)
     (command "._MOVE" (car Ent) "" (cadr Ent) PAUSE)
  (setvar 'OSMODE OS)
I hoped that changing these lines
to something like:
 (command "._MOVE" (car Ent) "b" "0,0" "0,-0.442")
would do it, but it doesn't so I am a bit lost now.
Any help would be appreciated.
P
Re: Move selected attribute by distance
« Reply #1 on: June 14, 2011, 12:39:39 PM »
Give this a try:
(defun c:moveattxt (/ mvpt ce os ent entprops lastpoint lastent *error*)
    (if os
      (setvar 'osmode os)
    (if ce
      (setvar 'cmdecho ce)
    (if lastent
      (entdel lastent)
  (setq os (getvar 'osmode)
ce (getvar 'cmdecho)
  (setvar 'cmdecho 0)
  (setvar 'osmode 0)
    (and
(while (not (and (setq ent (nentsel "\nSelect an attribute/text: "))
(= (length ent) 2)
(wcmatch (cdr (assoc 0 (setq entprops (entget (car ent))))) "ATTRIB,TEXT")
(setq mvpt (cadr ent)
       mvpt (list (car mvpt) (+ -0.442 (cadr mvpt)) (caddr mvpt))
ent
      (= (cdr (assoc 0 entprops)) "ATTRIB")
      (setq lastpoint (cadr ent)
    lastent   (entmakex
(cons
  (cons 0 "TEXT")
  (subst
    (cons 73 (cdr (assoc 74 entprops)))
    (assoc 74 entprops)
    (subst
      (cons
10
(cdr (assoc (if (= 0 (cdr (assoc 72 entprops)) (cdr (assoc 74 entprops)))
      10
      11
    entprops
      (assoc 10 entprops)
      (vl-remove-if
(function (lambda (g) (vl-position (car g) '(-1 0 2 5 70 73 100 280 330)))
entprops
     (progn (setvar "LASTPOINT" lastpoint)
    (command "._MOVE" lastent "" (cadr ent) mvpt)
    (if (not (equal lastpoint (getvar "LASTPOINT")))
      (progn (entmod (subst (assoc 11 (entget lastent))
    (assoc 11 entprops)
    (subst (assoc 10 (entget lastent)) (assoc 10 entprops) entprops)
     (entupd (car ent))
    (entdel lastent)
     (command "._MOVE" (car ent) "" (cadr ent) mvpt)
  (setvar 'osmode os)
;;(nentsel)
Pad
« Reply #2 on: June 14, 2011, 01:39:29 PM »
Thats perfect.  It wasn't as straightforward as I thought.
Thank you very much Ron.
« Reply #3 on: June 14, 2011, 04:34:39 PM »
 :-) You're welcome.
You could use something like this as well to shorten it up:
(defun c:moveatt (/ ent mvpt pt)
  (if (and (setq ent (nentsel "\nSelect an attribute/text: "))
   (wcmatch (cdr (assoc 0 (entget (car ent)))) "ATTRIB,TEXT")
   (setq pt (cadr ent))
   (setq mvpt (list (car pt) (- (cadr pt) 0.442) (caddr pt)))
    (vlax-invoke (vlax-ename->vla-object (car ent)) 'move (cadr ent) mvpt)
« Last Edit: June 14, 2011, 04:52:21 PM by ronjonp »
Pad
« Reply #4 on: June 14, 2011, 05:35:57 PM »
wow that's quite a bit shorter
Cheers
« Reply #5 on: June 14, 2011, 05:49:54 PM »
Or maybe slightly shorter still...  :-P
(defun c:moveatt ( / e ) (vl-load-com)
  (if (and (setq e  (car (nentsel "\nSelect an attribute/text: ")))
           (wcmatch (cdr (assoc 0 (entget e))) "ATTRIB,TEXT"))
    (vlax-invoke (vlax-ename->vla-object e) 'move '(0. 0. 0.) '(0. -0.442 0.))
« Reply #6 on: June 15, 2011, 10:38:05 AM »
And even shorter :P
(defun c:moveatt (/ e)
alanjt
  • Standby for witty remark...
« Reply #7 on: June 15, 2011, 10:52:02 AM »
And even shorter :P
Funny if taken out of context.
Dropbox
« Reply #8 on: June 15, 2011, 11:04:24 AM »
No grip edit if the attribute position is locked  :-D
alanjt
« Reply #9 on: June 15, 2011, 11:05:59 AM »
party pooper  :-P
Dropbox
Pad
« Reply #10 on: June 15, 2011, 04:47:42 PM »
thanks guys.
The grip edit way is the way I was doing it before, after a few it becomes a bit tedious.
alanjt
« Reply #11 on: June 15, 2011, 04:50:13 PM »
thanks guys.
I'm sure it is. If this was something I had to do on a regular basis, I'd code it too.
Dropbox
