Author Topic: LISP - plot command question  (Read 2559 times)
andrew_nao
« on: June 06, 2011, 04:56:41 PM »
im trying to print a section of a dwg to pdf but im getting undesirable results (the contents of the window selction is not printing to the pdf but other parts that werent selected are)
so i would like to know if someone else can give this a try and tell me if you get undesireable results or if it what you selected in the window is what appears
thanks
;DWG To PDF.pc3
(defun printpdfsect (/ fileloc filenam point pointa pointb)
(setq fileloc (strcat (getvar "dwgprefix")
                      (vl-filename-base (getvar "dwgname"))
(setq pointa (getpoint "\n Select first point: "))
(setq pointb (getcorner pointa "\n Select second point: "))
(setq point (list (car pointa) (cadr pointb)))
(command "-plot"
          "y"
 "DWG To PDF.pc3"
 "ANSI expand A (8.50 x 11.00 Inches)"
 "I"
 "P"
 "N"
 "W"
 (car point)
 (cadr point)
 "F"
 "Y"
 "nao.ctb"
 "Y"
          fileloc "n" "y")
(printpdfsect)
« Last Edit: June 09, 2011, 02:22:46 PM by CAB »
Re: can someone test this for me
« Reply #1 on: June 06, 2011, 08:22:03 PM »
Are you in WCS and are the snaps OFF?
andrew_nao
« Reply #2 on: June 07, 2011, 08:50:45 AM »
snaps are off
how do i check if im in WCS
Crank
« Reply #3 on: June 07, 2011, 12:13:23 PM »
(getvar "WORLDUCS")
andrew_nao
« Reply #4 on: June 09, 2011, 01:20:22 PM »
ok i need to revise this, i got it working but now i need to change it where it prompts with the dialog box to name it and save it to what the user wants
if i remove the fileloc variable it stops and if i put a pause or "" in place, it just blows right thru without asking
how can i get it to pause with the dialog box to ask for the user input
Re: LISP - plot command question
« Reply #5 on: June 09, 2011, 02:24:40 PM »
You will need to first collect that data from the user when you get point selections and then use it within the plot command.
andrew_nao
« Reply #6 on: June 13, 2011, 10:37:14 AM »
thanks for the help
i have 1 more question.
im trying to make it where if the person hit the escape key, that is ends quietly however when the escape is pressed the command still runs what am i missing in my error trapping?
(defun *error* (msg)
  (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,*EXIT*,")))
(defun printpdfsect (/ fileloc filename pointa pointb)
(setq filename (dos_getfilenav "Select Files" fileloc "PDF" 1))
(command "-plot"
          "y"
  "DWG To PDF.pc3"
  "Inches"
  "Landscape"
  "NO"
  "Window"
  pointa
  pointb
  "Fit"
  "Center"
  "YES"
  "nao.ctb"
  "YES"
  "As Displayed"
  filename
  "NO"
  "YES")
« Reply #7 on: June 13, 2011, 02:48:13 PM »
You need to test the return value from dos_getfilenav
Not sure what the value is when ESC is pressed but it must be a odd value like nil or -1 or something you can test for.
HTH
