Ok Cab,
I get the following error
; error: no function definition: MENU_CHANGE
I did lsp, function and menu_change was not loaded.
Once I loaded it in, I get this error
Command:
; error: bad argument type: stringp nil
which means I got a () or a "" issue so I will start looking at the code.
checked that...
I wonder if it is what I have in the mnu, due to the length it wrapped and I wonder if I got something typed in wrong...
^c^c^p
that does a double cancel and then toggles the menuecho
then
(if (null menu_change) (load menu_change))
this looks to see if "menu_change" is loaded, if it isn't it loads it.
(menu_change "lowes")
does this define menu_change as lowes?
I guess I don't see how it proceeds...
I re-did my menu part and put spaces between the ) ; (
and that made it do something more and comes back with two errors.
Command: ; error: bad argument type: stringp nil
Command:
_HELP
Command: HELP
Command: ; error: no function definition: MENU_CHANGE
this is urting my brain on top of the day I had so I am going to take off and try to get some sleep.
Pieter
