Cab,
I am looking at a way to load specific client menu when choosen via a menu pulldown or any other user selection. Just using menu pulldowns as it is the most basic.
The user starts Autocad. Then they can select the client that they are going to be doing work for. When they select the client, colortables, search paths and other variables will be set for that client.
The user works for a while and after lunch they need to work for another client. When they go to select their new client, it needs to unload the previous client. Then it will load in the new client menu and set all the system variables that it needs.
Maybe I am making this more complicated??? I probably have 30 different clients all with specific needs, colortables etc. This is my way to eliminate the use of profiles and have more control over variables and other things.
ELOQUINTET, I like the DCL idea, but I still need the code to load and unload menu's.
Thanks guys!
Pieter
