Author Topic: Help with Dimensions  (Read 1696 times)
pedroantonio
« on: May 13, 2011, 09:41:02 AM »
How to create a dimension like this image? To do this I have to change the UCS in every dimension.
There's a way to do without change the UCS?
Thanks.
Re: Help with Dimensions
« Reply #1 on: May 13, 2011, 11:10:54 AM »
THE _dimaligned COMMAND.
pedroantonio
« Reply #2 on: May 13, 2011, 03:43:53 PM »
CAB,
dimaligned command puts the dimension text parallel to dimension line. I need the text perpendicular to dimension line like show the image.
« Reply #3 on: May 13, 2011, 03:50:59 PM »
CAB,
find this setting under dimstyle: FIT Tab
Place Text Manually
Ignores any horizontal justification settings and places the text at the position you specify at the Dimension Line Location prompt. (DIMUPT system variable)
« Reply #4 on: May 13, 2011, 03:55:03 PM »
or see below:
The following prompts are displayed.
Specify first extension line origin or <select object>: Specify a point for manual extension lines, or press Enter for automatic extension lines
After you specify either manual or automatic extension lines, the following prompt is displayed:
Specify dimension line location or [Mtext/Text/Angle]: Specify a point or enter an option
Extension Line Origin
Specifies the first extension line origin (1). You are prompted to specify the second one.
Object Selection
Automatically determines the origin points of the first and second extension lines after you select an object.
For polylines and other explodable objects, only the individual line and arc segments are dimensioned. You cannot select objects in a nonuniformly scaled block reference.
If you select a line or an arc, its endpoints are used as the origins of the extension lines. The extension lines are offset from the endpoints by the distance specified in Offset from Origin on the Lines and Arrows tab of the New, Modify, and Override Dimension Style dialog boxes (see DIMSTYLE). This value is stored in the DIMEXO system variable.
If you select a circle, the endpoints of its diameter are used as the origins of the extension line. The point used to select the circle defines the origin of the first extension line.
Specifies the placement of the dimension line and determines the direction to draw the extension lines. After you specify the location, the DIMALIGNED command ends.
Mtext
Displays the In-Place Text Editor, which you can use to edit the dimension text. The generated measurement is represented with angle brackets (< >). To add a prefix or a suffix to the generated measurement, enter the prefix or suffix before or after the angle brackets. Use control codes and Unicode character strings to enter special characters or symbols. See Control Codes and Special Characters.
To edit or replace the generated measurement, delete the angle brackets, enter the new dimension text, and then click OK. If alternate units are not turned on in the dimension style, you can display them by entering square brackets ([ ]). For more information, see Change Existing Objects.
The current dimension style determines the appearance of the generated measurements.
Text
Customizes the dimension text at the command prompt. The generated dimension measurement is displayed within angle brackets.
Enter the dimension text, or press Enter to accept the generated measurement. To include the generated measurement, use angle brackets (< >) to represent the generated measurement. If alternate units are not turned on in the dimension style, you can display alternate units by entering square brackets ([ ]).
Dimension text properties are set on the Text tab of the New, Modify, and Override Dimension Style dialog boxes.
Angle
Changes the angle of the dimension text.
