Author Topic: ELM ----Is this correct?  (Read 2613 times)
Jeff H
« on: April 26, 2011, 07:28:01 PM »
I do not know if any of you have ran across this site http://art2.ph-freiburg.de/Lisp-Course      (to register you put in username and password in login area)
It's a basic beginners course to LISP
It checks your answers to see if they are correct, but I do not know if I am making functions that give correct answer but are poorly designed.
So here is the last one I did
MONOTON-ANSTEIGEND-P
Define a recursive predicate MONOTONIC-INCREASING-P, that has a number list as its argument. That predicate should test whether the numbers in the number list are in monotonic increasing order. This being the case, T is returned, otherwise NIL.
Examples:
(MONOTONIC-INCREASING-P '(1 2 5 7 9))
T
(MONOTONIC-INCREASING-P '(1 2 5 5 9 9))
T
(MONOTONIC-INCREASING-P '(1 2 5 3 9))
NIL
(MONOTONIC-INCREASING-P '())
T
Answer that was evaluated as correct
Is this Lispy?
(DEFUN MONOTON-ANSTEIGEND-P (NUMBERLIST)
   (COND
   ((ENDP NUMBERLIST) T)
   ((ENDP (REST NUMBERLIST)) T)
   ((> (FIRST NUMBERLIST)(SECOND NUMBERLIST)) NIL)
   (T (MONOTON-ANSTEIGEND-P (REST NUMBERLIST)))))
If anyone is a beginner and interested in doing some chapters maybe we could compare answers.
Re: ELM ----Is this correct?
« Reply #1 on: April 26, 2011, 07:31:59 PM »
Bear in mind that there are various dialects of LISP - AutoCAD uses AutoLISP.  Your code looks like Common LISP.
In AutoLISP it could be:
(defun MONOTONIC-INCREASING-P ( l )
  (if (cadr l)
    (if (<= (car l) (cadr l))
      (MONOTONIC-INCREASING-P (cdr l))
    t
Or
    ( (not (cadr l)) )
    ( (<= (car l) (cadr l)) (MONOTONIC-INCREASING-P (cdr l)))
Or
  (or (not (cadr l)) (and (<= (car l) (cadr l)) (MONOTONIC-INCREASING-P (cdr l))))
« Last Edit: April 26, 2011, 07:41:11 PM by Lee Mac »
Jeff H
« Reply #2 on: April 26, 2011, 07:58:41 PM »
Thanks Lee,
I thought it would still use same concept which is all that matters.
I was follwing their style but I like your implamentation's better.
I tested one and said it was wrong although used in the evaluation window it produced correct answer for all test case's which is confirming that correct answer must match their implamentation.
Would this fail given a list with 1 item
    ( (not (cadr l)) )
« Reply #3 on: April 26, 2011, 08:07:33 PM »
Thanks Lee,
Same concept, different syntax. Bear in mind there are some functions in Common LISP which don't exist in AutoLISP and vice-versa.
Depends whether you want a single item list to return T or nil   :roll:  I vote it should return T
Jeff H
« Reply #4 on: April 26, 2011, 08:28:53 PM »
I was looking at that site because I have quickly looked over AutoLisp tutorials and have not seen good explanations of it at a lower level.
To me it makes it easier to understand how it works a little deeper and that site started to look promising but has got into the style of 'If given A just remember do B'
instead of 'If given A here is why B and this is why C fails......etc'
but the bigger question I am asking myself is why have I not just realized I am surrounded by Lisp pro's and just ask the questions here.
I guess I am doing the normal learning stages in getting academic style knowledge and then have 'real-world' experts relearn you the correct way.
So instead of this great site teaching me that every COND first terminating case should check for empty list
just ask one of you 'real-world programers' who write code that actually is used in solving real life problems
« Reply #5 on: April 26, 2011, 11:16:44 PM »
Well I hope you considered these too:
-----------  Programing References  ------------
http://www.autodesk.com/techpubs/autocad/acad2000/dxf/index.htm   DXF Codes
http://www.analogx.com/contents/articles/howtoprg.htm  So you want to be a Programmer...
http://pages.cs.wisc.edu/~vernon/cs367/notes/6.RECURSION.html  Recursion
http://jefferypsanders.com/autolisp.html
http://www.geocities.com/siliconvalley/2151/matrices.html
Volume 1 of The Art of Computer Programming
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html#%_toc_start    CONTENTS
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-38.html#%_index_start    INDEX
--------------  Links by CAB  -----------------
http://www.theswamp.org/index.php?topic=26955.msg326759#msg326759
To get off the ground in a hurry you should read from these sites:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/files/WS73099cc142f48755-381799d411f6fb5af15-62c4.htm
Start at the beginning   http://www.afralisp.net/
http://ronleigh.info/autolisp/index.htm
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=770225
http://sites.google.com/site/skatterbrainz/vldb
Intermediate to Advanced:
Advanced:
http://www.atablex.com/htmls/excel-bible.htm
The Visual LISP Developer's Bible (eBook)   [***  Get this ***]
http://carnet-de-cablage.chez-alice.fr/Doc/lakose_The_Visual_LISP_Developers_Bible.pdf
http://www.caddigest.com/subjects/autocad/tutorials/select/parsai_vlx.htm
References:
http://www.hyperpics.com/commands/index.asp
Extra credit:
http://www.paulgraham.com/progbot.html
http://www.dreamsongs.com/SeatBelts.html
http://www.dreamsongs.com/ArtOfLisp.html
I found these links too but have not explored them.
Link to pdf Lessons:
http://forums.augi.com/showpost.php?p=190406&postcount=21
14 lessons by Dave Pitzer
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2309147
follow the link at the bottom of each lesson
Free AutoLisp course
http://forums.augi.com/attachment.php?attachmentid=3425&d=1093637254
Computer Science 50: Introduction to Computer Science I Harvard College
http://cs50.tv/
http://www.asmitools.com/Files/Programs.html
http://www.asmitools.com/Files/Tutorials.html
http://www.softwarepreservation.org/projects/LISP/book/LISP%201.5%20Programmers%20Manual.pdf
http://augiru.augi.com/content/library/au07/data/paper/CP311-4.pdf
Jeff H
« Reply #6 on: April 27, 2011, 12:28:43 AM »
Thanks CAB will look through them.
