I have a routine that searches a dwg for every instance of a block and inserts another block at the insertion points of the first set of blocks, then they match up attributes. If the ucs is not set to world why does the tool insert the second set of blocks to another location not at the insertion point of the first set of blocks? Is there a way using trans to fix this? or maybe some other way?
